Intel Unveils Thunderbolt 3
Intel® unveils Thunderbolt™ 3, the fastest, most versatile connection to any dock, display, or peripheral device – including billions of USB devices.
Intel® unveiled the Thunderbolt™ 3, the fastest, most versatile connection to any dock, display, or peripheral device – including billions of USB devices.
“Thunderbolt™ 3 is computer port nirvana – delivering two 4K displays, fast data, and quick notebook charging”, said Navin Shenoy, vice president in Client Computing Group and general manager of Mobility Client Platforms at Intel Corporation. “It fulfills the promise of USB-C for single-cable docking and so much more. OEMs and device developers are going to love it.”
Users have long wanted desktop-level performance from a mobile computer. Thunderbolt was developed to simultaneously support the fastest data and most video bandwidth available on a single cable, while also supplying power. Then recently the USB group introduced the USB-C connector, which is small, reversible, fast, supplies power, and allows other I/O in addition to USB to run on it, maximizing its potential. In the biggest advancement since its inception, Thunderbolt 3 brings Thunderbolt to USB-C at 40Gbps, fulfilling its promise, creating one compact port that does it all.
Computer ports with Thunderbolt 3 provide 40Gbps Thunderbolt – double the speed of the previous generation, USB 3.1 10Gbps, and DisplayPort 1.2. For the first time, one computer port connects to Thunderbolt devices, every display, and billions of USB devices. In Thunderbolt mode, a single cable now provides four times the data and twice the video bandwidth of any other cable, while supplying power. It’s unrivaled for new uses, such as 4K video, single-cable docks with charging, external graphics, and built-in 10 GbE networking. Simply put, Thunderbolt 3 delivers the best USB-C.
At 40Gbps, it is the fastest connection to your computer. You can transfer a 4K movie in less than 30 seconds. You can connect two 4K displays with nearly 16 million more pixels than an HDTV.
Connect two 4K 60 Hz displays with astonishing resolution, contrast, and color depth to see your photos, videos, applications, and text with amazing detail.
Best Single-Cable Docking
Now, one compact port provides Thunderbolt 3 data transfer, support for two 4K 60 Hz displays, and quick notebook charging up to 100W with a single cable. It’s the most advanced and versatile USB-C docking solution available.
External Graphics
Gamers can now connect plug ‘n’ play external graphics to a notebook to enjoy the latest games at recommended or higher settings.
Thunderbolt™ Networking
Provides a peer-to-peer connection at 10 GbE speeds to quickly transfer files between computers, perform PC migrations, or set up small workgroups with shared storage.
Solutions and products built to Thunderbolt and Thunderbolt 2 specifications will work with Thunderbolt 3 via an adapter.
Initial products with Thunderbolt 3 are expected to begin shipping before the end of this year, and ramp in 2016.
Technology Features
- Thunderbolt™, USB, DisplayPort, and power on USB-C
- USB-C connector and cables (small, reversible)
- 40 Gbps Thunderbolt™ 3 – double the speed of Thunderbolt 2
- Bi-directional, dual-protocol (PCI Express and DisplayPort)
- 4 lanes of PCI Express Gen 3
- 8 lanes of DisplayPort 1.2 (HBR2 and MST)
- Supports two 4K displays (4096 x 2160 30bpp @ 60 Hz)
- USB 3.1 (10 Gbps) – compatible with existing USB devices and cables
- DisplayPort 1.2 – compatible with existing DisplayPort displays, devices, and cables
- Connect DVI, HDMI, and VGA displays via adapters
- Power (based on USB power delivery)
- Up to 100W system charging
- 15W to bus-powered devices
- Thunderbolt™ Networking
- 10Gb Ethernet connection between computers
- Daisy chaining (up to six devices)
- Lowest latency for PCI Express audio recording
SOURCE: Thunderbolt Technology
Why It Matters:
Previous versions of the Thunderbolt have been too large to implement into mobile devices; the new size will mean a transformative feature for most mobile devices, bringing the industry one step closer to achieving massive power and speed with smaller connectivity.
