News
IRIS Enables Sophisticated IoT
June 19, 2015 by Jennifer A. Diffley
Altierre's new Iris System-on-Chip allows for massive Internet of Things.
Altierre Corp, known for producing ultra-low power wireless technology, unveiled a new Wireless System-on-Chip named Iris. In Greek mythology, Iris is known as the messenger of the gods, so the namesake is fitting, given that Altierre's new chip can seamless enable thousands of IoT devices over a long range. This is especially applicable in industrial settings, where thousands of sensors and display tags may now be used to communicate with each other with low power over Altierre's RF network. Devices utilizing the low profile 2-way RF are powered by coin cell batteries that provide 5-10 years of life while remaining consistently connected.
Especially impressive is that the Altierre wireless access points can integrate millions of IoT sensors, enabling massive warehouses to remain connected across long range and without line of sight while intelligently channel hopping to improve security.
“Operating 65,000 ultra-low power RF clients in a single building with only a couple of access points, and bi-directional data communication to each client, truly shows our ability to meet the most complex wireless challenges," said Altierre Chairman and CEO Sunit Saxena.
The IRIS chip could, for example, enable a warehouse store to change the prices of hundreds of thousands of products at the push of a button. Or a theme park to manage and coordinate a huge network of displays. IRIS maintains ultra low power while featuring a "2-way RF communication block, digital control block, onboard sensors, A/D converter, an intelligent onboard controller and a variety of interfaces to external sensors and display controllers." In time, technology like IRIS could ensure that the IoT is just as complex and communicative as the traditional internet.
SOURCE: Altierre
1 Comment
  • S
    satyapal June 23, 2015
    Power Factor Controllers, in the 1st Stage – fixed value capacitors are added in parallel to individual motors or loads. This is a Crude method of Power Factor Correction. In the 2nd Stage – is the conventional Power Factor Controller that incorporates a Set of Discrete value capacitors that are switched ON & Off to the value required through a set of Contactors & a POWER FACTOR SENSING RELAY.
