The intuitive, step-by-step procedure presented in this article will help you to successfully perform reflow soldering in your toaster oven.
Required Hardware/Software
The System and the Profile
This article presents a detailed, adaptable procedure whereby any ordinary toaster oven can be forced to reproduce, with reasonable accuracy, a reflow-soldering temperature profile. The first thing you will need is the thermocouple measurement system developed in a previous article (Make an EFM8-Based System for Monitoring and Analyzing Thermocouple Measurements); if you already have some sort of hardware/software combination for collecting, recording, and visualizing thermocouple measurements, feel free to give it a try. You should also read Introduction to Manually Controlled Toaster Oven Reflow, which describes the benefits of DIY reflow, suggests some features to look for in a toaster oven, discusses the data-collection hardware setup, provides background information on reflow temperature profiles, and presents the specific profile that we will be using. You will probably want to refer back to this profile as you read through this article, so I’ll include it here for your convenience.
Before we get started, note the following in regard to the data-collection process:
  • All the temperature records in this article were generated using 5-second intervals between measurements
  • Allow the thermocouple to return to room temperature before you start a new data-collection run.
  • Click “Begin Temperature Data Collection” right before you activate the oven.
  • Make sure that the thermocouple junction remains close to the surface of the PCB; it might get tweaked out of place when you close the door. If you cannot conveniently run the thermocouple through the gap between the door and the metal frame, you could insert the thermocouple through a small hole drilled in the back of the oven.
  • My oven’s temperature dial is labeled only with Fahrenheit, so you will notice some irksome switching-back-and-forth between Celsius and Fahrenheit throughout the rest of this article. Obviously, you can avoid this annoyance by using an oven with Celsius labels.
And one last note: This probably goes without saying, but solder paste contains chemicals that you don’t want anywhere near your food. Make sure everybody in your office or home knows that your “reflow” oven is for soldering, not cooking.
Step 1: Fire and Forget
Let’s start with the hands-off approach and see if the toaster oven can fend for itself. We will aim for 215°C, because this is the middle of the peak temperature range. The profile indicates that the ideal duration is 300 seconds to peak. Thus, for this first run we set the function to “bake,” the temperature to 215°C (aka 419°F), and the timer to 5 minutes. Here are the results:
Hmm. . . . Black & Decker will have to refine their temperature control algorithm if they plan to market this thing as a reflow oven. Let’s see—we overshot the intended peak temperature by 60°C (and therefore exceeded the maximum temperature by 50°), we remained in the reflow zone for way too long, and the overall shape of the temperature curve is thoroughly inconsistent with the profile. The oven did indeed turn off at about 300 seconds, so at least the timer is accurate, but this is not apparent in the data because the temperature decreases very slowly without any active heat removal. Conclusion: FAILURE.
Step 2: The Search for Peak Temp
First let’s address this peak temperature problem. We need to find the temperature setting that actually corresponds to 215°C. My first guestimate is 390°F (199°C) on the dial. Everything else for this run is the same as in the previous run. Here are the results:
This time we exceeded the intended peak temperature by only 35°C (last time was 60°C), so we’re getting closer. Let’s try 350°F (177°C) on the dial, with everything else the same.
This looks pretty good. The measured peak temperature was 210°C. So now we know an approximate temperature setting that will help the actual temperature to converge toward our desired peak of 215°C. Also, we can see from the first three runs that the oven naturally produces a rate of temperature increase (in this case about 1.4°C/second) that is far below the maximum, so we don’t need to worry about that part of the profile. The only problem with this run is indicated by the flat portion of the temperature curve—this temperature setting for some reason led the control system into a different operational region, such that the heating elements turned off for a while then turned on again to reach the final temperature. We want a setting that will take the temperature directly to the peak with no delays—it’s fine if the final temperature is a little too high because we can easily fine-tune the peak by simply shutting off the oven. It turns out that an appropriate setting is 375°F (191°C):
As you can see, this setting takes the oven directly and smoothly to an excellent peak temperature; we can shut off the oven before the heating elements kick in and cause the final increase to 230°C.
Step 3: Refining the Profile
Now we need to make the measured profile look more like the recommended profile. This means manually turning the oven on and off to 1) create a better soak phase, 2) enforce an appropriate amount of time in the reflow phase, and 3) fine-tune the peak temperature. Here is the specific procedure used to generate the next temperature curve:
  1. Set the temperature to 375°F and turn on the oven by moving the timer to about 10 minutes—that is, long enough to ensure that the oven does not shut off before we manually shut it off.
  2. Keep your eye on the numeric temperature display. When the temp reaches 140°C (i.e., the lower bound of the soak-phase temperature range), do whatever it takes to deactivate the heating elements. I accomplish this by quickly turning the temperature dial to its minimum setting.
  3. Wait until the temperature reaches the upper bound of the soak range (160°C), then reactivate the heating elements. The temperature setting should be the same as when you started, in this case 375°F.
  4. Deactivate the heating elements when the temperature reaches the desired peak (i.e., 215°C).
We can immediately see that our temperature curve looks much more like the profile. This is good. But we still have three problems, as indicated in the image:
  • We significantly overshot the intended peak temperature.
  • The temperature leveled out above the soak range.
  • The length of time above the melting point is still way too long.
The first two shortcomings originate from the same mistake; namely, not accounting for lag in the temperature response. The heating elements remain hot after they are deactivated, and we need to compensate for this by making adjustments earlier. The third problem occurs because the temperature decreases too slowly—we are not actively removing heat from the oven, so everything stays hot. Fortunately, there is a very simple solution: open the oven door. Here is the procedure used to generate the final temperature curve:
  1. Set the temperature to 375°F and turn on the oven.
  2. When the temp reaches 130°C, deactivate the heating elements.
  4. Deactivate the heating elements when the temperature reaches 205°C.
  5. When the temperature reaches 215°C, open the door.
Success! Look through the annotations for this curve, and you will see that all our critical reflow specifications have been met. The only (minor) violation is the length of the reflow phase, which should be at least 60 seconds. You could easily remedy this by waiting a few more seconds before opening the door. You could also perform the first heating-element deactivation a little sooner in order to move the soak-phase portion of the curve closer to the center of the specified soak-phase temperature range. Bottom line, this profile should be more than adequate for DIY, prototype-quality reflow.
I hope this procedure helps you to enjoy the benefits of reflow soldering without the cost and inconvenience of professional assembly and without purchasing a host of expensive equipment and supplies. Keep an eye out for future articles that will provide tips and techniques for the other primary steps in DIY reflow: solder paste application, component placement, and post-reflow touch-up.
2 Comments
  • akulkis 2015-12-21
    Hook the thermocouple up to the Analog input pins of an Arduino, and have some digital out pins control a triac that turns the heating elements on and off.  For even better fine-tunning, use pulse-width-modulation on the TRIAC controlling the heating elements.  An Arduino Uno model would be overkill and it only costs about $10 in the U.S.  Triac, and a power supply would be about another $10.
  • nickpaton 2015-12-24
    I’m very interested in this project as it reminds me of the oven I developed some years ago as part of a complete IR reballing service I offered at the time (sadly no longer).
    The oven was a much modified commercial Lincat IR grill unit, with temperature control using a similar (but not so good) set up to the one you’re describing. The control board and PC control interface was supplied by a little French company (long gone), and once sorted worked very well.
    The reason for posting this is to show the (rough!) video of the whole ball grid array (BGA) reballing process I made at the time, including the part where the solder balls are soldered to the chip in the oven (between 3:11 and 4:10). https://www.youtube.com/watch?v=q—U1axjD74 .
    The camera used for for recording the macro views was based on a near field macro lens from Edmunds Optics, and it’s interesting to observe how the tiny 0.6mm dia solder balls move around and centre themselves on the chip solder pads as the solder melts; also around 5:08 the newly reballed chip can be seen moving and centring on the motherboard solder pads as the BGA melts (this was the primary function of the macro camera, providing a simple check that the chip was properly soldered to the motherboard).
    Note: the company who’s details are shown on the vid has been closed a long time ago and likewise I’ve left the industry, so there’s no commercial intent etc.
