Project
Interface an LCD with an Arduino
April 16, 2015 by Tim Youngblood
You can easily interface a liquid crystal display (LCD) with an Arduino to provide a user interface.
Liquid crystal displays (LCDs) are a commonly used to display data in devices such as calculators, microwave ovens, and many other electronic devices..
In this tutorial, I will show you how to use a 16x2 LCD with an Arduino. The 16x2 LCD used in this experiment has a total of 16 pins. As shown in the table below, eight of the pins are data lines (pins 7-14), two are for power and ground (pins 1 and 16), three are used to control the operation of LCD (pins 4-6), and one is used to adjust the LCD screen brightness (pin 3). The remaining two pins (15 and 16) power the backlight.The details of the LCD terminals are as follows:
Terminal 1 GND
Terminal 2 +5V
Terminal 3 Mid terminal of potentiometer (for brightness control)
Terminal 4 Register Select (RS)
Terminal 5 Read/Write (RW)
Terminal 6 Enable (EN)
Terminal 7 DB0
Terminal 8 DB1
Terminal 9 DB2
Terminal 10 DB3
Terminal 11 DB4
Terminal 12 DB5
Terminal 13 DB6
Terminal 14 DB7
Terminal 15 +4.2-5V
Terminal 16 GND
LCD pins
LCD pins
Experiment 1
In this experiment, we will interface a 16x2 LCD with Arduino Mega 2560 and display some text on the LCD.
Hardware Required
  • 1 x 16x2 LCD
  • 1 x Arduino Mega 2560
  • 1x 5k ohm potentiometer
  • female connectors
  • jumper wires
Wiring Diagram
In this circuit, the LCD terminals are connected to the Arduino pins according to the table below. Connect the outer two terminals of the potentiometer to 5V and ground, and the middle terminal to pin 3 of LCD. Rotating the potentiometer controls the brightness of the LCD backlight. The LCD back light pins are connected to 5V and ground as shown in the diagram below:
DB4----->pin4
DB5----->pin5
DB6----->pin6
DB7----->pin7
RS-----> pin8
EN-----> pin9
Circuit Diagram
Circuit Diagram
Code
#include "LiquidCrystal.h"
// initialize the library by providing the nuber of pins to it
LiquidCrystal lcd(8,9,4,5,6,7);
void setup() {
lcd.begin(16,2);
// set cursor position to start of first line on the LCD
lcd.setCursor(0,0);
//text to print
lcd.print("   16x2 LCD");
// set cusor position to start of next line
lcd.setCursor(0,1);
lcd.print("   DISPLAY");
void loop()
Interface_LCD_Arduino.zip
Experiment 2
In this experiment, we will display the 'value of' counter in the Arduino. It will count the number of seconds, up to a value of 100.
Hardware Required
The hardware required for this experiment is the same as for Experiment #1.
Wiring Diagram
The circuit for this experiment is the same as for Experiment #1.
Code
void setup() {
lcd.begin(16,2);
lcd.setCursor(0,0);
//text to print
lcd.print("    COUNTER");
delay(100);
int a=0;
lcd.setCursor(0,1);
lcd.print("       ");
lcd.print(a);
while(a<=100)
  a=a+1;
  delay(1000);
  lcd.setCursor(0,1);
  lcd.print("       ");
  lcd.print(a);
void loop()
  lcd.clear();
Interface_an_LCD.zip
Videos
7 Comments
  • Y
    yachtSamba January 03, 2017
    my mac says ‘could not create the sketch’
    • RK37 January 19, 2017
      Hi yachtSamba. You might be able to get some help with your specific problem by means of a post in the forum. Here is a link to our projects forum: http://forum.allaboutcircuits.com/forums/the-projects-forum.6/
  • Boris Davenport January 29, 2017
    This is a good article and will be very much useful to beginners. Using LCD shield is the best option.
