A Teardown of the Hitachi SJ Series P1 Variable Frequency Drives
April 13, 2020 by Nilo MitraThis teardown looks at the inner workings of the Hitachi SJ P1 Variable Frequency Drive, an inverter for industrial applications.
The new Hitachi SJ Series Type P1 Variable Frequency Drive is part of a line of industrial inverters. The SJ-P1 inverter achieves high torque at low speeds for heavy loads, making it a suitable option for a wide variety of applications.
Figure 1. The Hitachi SJ Series P1 variable frequency drive.
The SJ-P1 inverter can be used to drive both induction motors and permanent magnet motors. While induction motors are more commonly found in motor-driven systems, they are often larger in size and less efficient than permanent magnet motor solutions. While permanent magnet motor solutions tend to have a higher initial cost, they may offer a smaller size for more compact mechanical packages and higher efficiency. Although the permanent magnet motor offers many benefits, there is a problem of permanent magnet demagnetization when the inverter is overloaded over time. The SJ-P1’s over-current trip feature uses many isolated current detection and protection components to prevent the inverter from overloading and suppresses the demagnetization of permanent magnet motors.
The SJ-P1 Series is designed for easy integration with various networks using optional Fieldbus modules like RS485-Modbus (built-in), RS422 port (built-in), Ethernet, EtherCAT, ProfiNET and Profibus-DP.
The SJ-P1 inverter is used in a wide variety of applications including industrial fans, hydraulic pumps, cranes and lifts used in warehouse automation and injection molding machines. Now, let's take a look at the inner workings of this piece of equipment.
General Specifications
- Model and Ratings: SJ-P1, 15kW, 35A, 3-phase 400V class
- Sine-wave PWM system
- 0.00 to 590.00 Hz output frequency range
- Protection functions: Overcurrent error, overload error, brake resistor overload, overvoltage error, memory error, undervoltage error, current detector, etc.
External and Enclosure
- Dimensions: 390mm x 245mm x 190mm
- Weight: 16kg
- Operating ambient temperature: -10° to 40°C
- Installation class: A maximum altitude of 1000m, without gases or dust
Figure 2. The Hitachi SJ Series P1 enclosure.
DC Bus Capacitor
- DC Bus Bulk Capacitor: Nippon Chemi-con (2pcs) 400V/4400µF electrolytic capacitors.
Figure 3. The DC bus capacitor.
Main Controller Board
- PWM MCU: Renesas R5F571MFCDFC industrial equipment-specific real-time engine. A 32-bit microcontroller capable of operation up to 240 MHz.
- Programmable Logic Device: Altera EPM240T100I5N. The MAX® II family of instant-on, non-volatile CPLDs with densities from 240 to 2,210 logic elements (LEs) and non-volatile storage of 8Kbits.
- Isolation: Toshiba
- TLP2362 (4pcs) 10Mbd high-speed photocoupler.
- TLP2301 (4pcs) 20 kbps photo-transistor with high-speed detector.
- TLP291 photo-transistor.
- TLP290 (4Pcs) photo-transistor with AC inputs.
- Relay: Panasonic JQ1-5V-F general purpose relays 5A, 5VDC, 400mW SPDT (1 Form C).
- Relay: Fujitsu FTR-F3AA012E general purpose relays, 12VDC, 200mW SPST (1 Form A).
- Line input and three-phase output contactor board.
- Current transducer: LEM HLSR 62-P (2pcs) open-loop 62A current transducer with galvanic separation.
- Capacitor: Okaya LE 105 310V 1µF film capacitor.
- Resistor: Iwaki 3.3/6.6ΩJ (8pcs) resistor.
Figure 4. The main controller board.
Line Input and 3-Phase Output Contactor Board
- Current Transducer: LEM HLSR 62-P (2pcs) open-loop 62A current transducer with galvanic separation.
Figure 5. Line input and three-phase output contactor board.
Power Electronics Board
- IGBT: Fuji Electric 7MBR100VR120-50 1200V 100A IGBT module with rectifier, brake, inverter and thermistor stage.
- Isolation: Broadcom (Avago Technologies)
- ACPL-W61L (3pcs) ultra-low-power 10MBd digital CMOS optocoupler.
- ACPL-C87A precision optically isolated voltage sensor with 0.5% high gain accuracy.
- ACPL-C79A precision miniature isolation amplifier with 0.5% high gain accuracy.
Figure 6. The power electronics board.
- ACPL-336J (6pcs) 2.5A IGBT gate drive optocoupler with integrated (VCE) desaturation detection, active Miller clamping, fault, and UVLO status feedback.
- ACPL-W341 3A output current IGBT gate drive optocoupler with rail-to-rail output voltage.
- ACPL-W61L (4pcs) ultra-low-power 10MBd digital CMOS optocoupler.
- ACPL-C87A (2pcs) precision optically isolated voltage sensor with 0.5% high gain accuracy.
Figure 7. Another view of the power electronics board.
- Isolation: Toshiba TLP385 (13pcs) photo-transistor with 5000Vrms in a 4-pin SO6L package.
- Switching Power Supply: ON Semiconductor 2SK3748 N-channel 1500V 4A power MOSFET.
- Capacitor: Nichicon (2pcs) 400V/150µF electrolytic capacitor.
- Capacitor: Okaya
- LE 105 (3pcs) 310V 1µF film capacitor.
- HCP474 (2pcs) 0.47µF 1250VDC capacitor.
