Miniature IP67 Sealed Wire-to-Wire Connectors
TE Connectivity Miniature IP67 Sealed Wire-to-Wire Connectors are designed for use in outdoor lighting, commercial refrigeration lighting, kitchen appliances, HVAC equipment, and other high humidity applications.
The connectors use a compact design while still providing protection against dust and immersion. They accommodate 22 to 18 gauge wires and are available with two or three positions. Rubber seals are pre-assembled to reduce installation time, and connectors are available in black, red, and white to facilitate identification and correct assembly.
TE Connectivity Miniature IP67 Sealed Wire-to-Wire Connectors are rated for up to 5 A and 400 VAC, and they have an operating temperature of -40°C to +105°C.
  • Dimensions:
    • 3-position receptacle: 10.40 x 8.75 x 21.40 mm
    • 3-position plug: 9.70 x 8.15 x 16.20 mm
  • Housing: PA, UL 94 V-0
  • Contact: copper alloy with tin plating
  • Mechanical durability: 30 cycles
More Information
1 Comment
  • N11778 2017-04-25
    5 amps?  “Not”  copper alloy with tin plating “ooh” That should last in moisture
