This episode of Tech Specs is part of a video series highlighting the features, applications, and technical specs of newly released products.
TE Connectivity's T9G Relays
Some people think that bigger is better, but whoever designed TE Connectivity’s Potter & Brumfield 30A relay T9G series clearly disagrees, because T9G relays are 30% smaller than TE’s T9A relays. And even though they use the same footprint, T9G relays take up 13% less board space and consume up to 10% less energy. That makes the T9G the smallest relay in its class and perfect for saving board space in HVAC, appliance, and industrial control applications. The T9G relay also gives designers complete flexibility. It’s offered with normally open, normally closed, and changeover contacts, coil voltages from 5 to 110 V. The relays are available with standard through-hole PCB terminals, but certain configurations have PCB and quick connect terminals, making them even easier to install. T9G series relays also have UL, VDE, and CQC certifications and are RoHS compliant, so you can use these super small, super flexible relays across the globe.
  • Rated current: 30 A
  • Compared to T9A: 30% smaller, 13% less board space, 10% less energy
  • Contacts: 1 form A (NO), 1 form B (NC), 1 form C (CO)
  • Coil voltages: 5 VDC to 110 VDC
  • Termination: PCB terminals, PCB+Quick Connect
  • UL, VDE, CQC certifications, RoHS compliant
More Information
Learn More About:
0 Comments
