Category: Operational Amplifiers
10kW 3-Phase 3-Level SiC Grid Tie Inverter Reference Design
TI is unleashing the power of silicon carbide with a new, verified reference design that provides an overview on how to implement a three-level, three-phase SiC based DC:AC grid-tie inverter stage. In this video you will learn the advantages of a three-level topology; what TI technology is driving the SiC MOSFETs;  how and where are we sensing V & I; what is behind the digital power…
Supplied: Texas Instruments
Achieve Precise Measurement for Smoke Detector Designs
This video provides an introduction to the internal components of typical smoke detectors.
Automotive Current Monitoring Using High Speed Amplifiers
This video provides an overview of current shunt monitoring for automotive applications using the OPA365-Q1 high speed amplifier, the TLV314-Q1 op amp, LMV393-Q1 comparator and the TMS320F28052 microcontroller.  An overview of TI's reference design, or TI Design, for an automotive EV/HEV HVAC compressor is also provided in this video.
Demystifying circuit design with Precision DAC Part 1
The presentation addresses the Precision DAC Architecture overview, DAC spec parameters and the theory of operation & Design example. All the information is importer for engineer when work on the system design.Part 1: Speaker starts from a Precision DAC portfolio table to introduce the features as well as the popular application in the industrial market.
Demystifying circuit design with Precision DAC Part 4
The presentation addresses the Precision DAC Architecture overview, DAC spec parameters and the theory of operation & Design example. All the information is importer for engineer when work on the system design.Part 4: In this part, the speaker further introduces Glitch and its sources, major carry transition, glitch vs. DAC structure, glitch reduction techniques … etc.
Environmental sensor for building automation design Part 1
Building automation system is a communication network infrastructure that manages the building service. This training will introduce the environmental sensor black diagram, key reference design and the solution for IC temperature sensor, power saving analog temperature sensor, digital temperature sensor … etc.Part 1: The speaker introduces what building automation about, what is the role of…
Environmental sensor for building automation design Part 3
Building automation system is a communication network infrastructure that manages the building service. This training will introduce the environmental sensor black diagram, key reference design and the solution for IC temperature sensor, power saving analog temperature sensor, digital temperature sensor… etc.Part 3: The training introduce the passive infrared (PIR) sensor in building…
How to Design Transimpedance Amplifier Circuits
Learn how to convert an input current that ranges from 0 uA to 50 uA to an output voltage that ranges from 0 V to 5 V.  The frequency of the input signal is 10kHz and the supply voltage is +/-15V.
IMS2015 - TSW12J54 Demo
This demo showcases the TSW12J54 reference design which includes the ADC12J4000 (4 GSPS, 12-bit ADC) driven by the LMX5401 very high bandwidth differential driver.
Low Power PIR Motion Detector Design: Analog vs. Digital Solutions
Curious about the fundamentals of motion detection? Not sure where to start? This short video covers the basics of PIR motion detectors, the differences between analog and digital solutions, and how to design the right motion detector circuit for any application (such as video surveillance, lighting systems, and building security). After watching this video, you will be familiar with:How…
Operational Amplifiers (Op Amp) Technology Overview
What is the difference between a CMOS, Bipolar, and JFET amplifier?  When should you use one over another?  When should you use an amplifier with no input crossover distortion, and what is input crossover distortion?  What about Zero-Drift, Chopper, and auto-zero amplifiers?  This training will provide you with the tools necessary to effectively choose and implement the most…
Polyphase Current Measurement with Isolated Shunt Sensors: Implementing isolated shunt sensors using
This module discusses the different building blocks that are used in isolated modulator implementations that use digital filters that are integrated within the MCU.  We will provide details on designing the hardware for these components.  This is the first of two modules for the “Implementing isolated shunt sensors using isolated delta sigma modulators and digital filters” section of…
TI Precision Labs - Op Amps: Bandwidth - Lab
TI Precision Labs is the electronics industry’s first comprehensive online classroom for analog engineers. This video provides an overview of the curr...TI Precision Labs TI Precision Labs is the electronics industry’s first comprehensive online classroom for analog engineers. The on-demand curriculum pairs theory and applied lab exercises to deepen the technical expertise of experienced…
TI Precision Labs - Op Amps: Bandwidth 1
TI Precision Labs - Op Amps: Bandwidth 2
TI Precision Labs - Op Amps: Bandwidth 4
TI Precision Labs - Op Amps: Board Level Troubleshooting
Board level troubleshooting is an approach for best practice application debugging techniques. Various engineering checks are outlined to help determine the root cause of an issue. In this video we discuss a technique known as the A-B-A swap, as well a
TI Precision Labs - Op Amps: Common Mode Rejection
TI Precision Labs - Op Amps: Comparator Applications 1
