Industry White Paper
How to Measure and Reduce Common Mode EMI in Electric Drive Installations
October 05, 2021 by Rohde & Schwarz Download PDF
White Paper Overview
Nowadays, electric machines are often driven by power electronic converters. Even though the use of converters brings with it a variety of advantages, common mode (CM) signals are a frequent problem in many installations. Common mode voltages induced by the converter drive common mode currents damage the motor bearings over time and significantly reduce the lifetime of the drive. Hence, it is essential to measure these common mode quantities in order to take suitable countermeasures.
In this white paper, discover a simple and reliable way to accurately determine the required quantities and the effectiveness of different countermeasures.
Learn More About:
  • Common mode noise
  • Problems with common mode noise in power drive systems
  • Measuring CM quantities
  • Countermeasures
Read White Paper:
Already an AAC member? Please Click Here to login.
