Industry White Paper
Universal USB-C Charger Designs Enabled by Programmable Power Supply
September 29, 2021 by Infineon Technologies Download PDF
White Paper Overview
Before introducing USB Type-C connectors and power delivery, laptops and mobile phone manufacturers implemented proprietary power adapters to charge the devices. With the introduction of USB Type-C connectors by USB-IF (USB Implementers Forum), device manufacturers are moving away from proprietary designs to adopt USB Type-C connectors and ports. The new USB Type-C protocol supports charging at up to 100 W over the VBUS and uses a reversible connector for added convenience.
This paper provides an overview of the USB Type-C and power delivery specifications, programmable power supply (PPS) considerations, and how a typical battery charging system works. The paper also compares charging various sink devices (phones) with a non-PPS charger and a PPS charger and discusses the advantages of designing a universal USB Type-C charger with PPS support. Finally, it provides examples of a USB Type-C PPS power adapter design based on Infineon’s EZ-PD™ CCG3PA and EZ-PD™ PAG1 controller.
Register below to access the white paper.
White Paper Authors: Anshul Gulati, Principal Application Engineer, Infineon Technologies Shopitham Ram, Senior Staff Application Engineer, Infineon Technologies
Check out Infineon's related online trainings HERE.
Check out the links below for more related reference designs and demo boards:
Read White Paper:
Already an AAC member? Please Click Here to login.
