Industry White Paper
Using USB-C PD to Sink or Source Power in Battery-powered Applications
February 19, 2024 by Infineon Technologies
Topics Covered
  • Infineon's EZ-PD™ PMG1-B1 technical product features
  • Testing use cases
  • Configuration walk-through
Application Note Overview
Download this exclusive application note and read about Infineon's EZ-PD™ PMG1-B1 high voltage microcontroller with USB-C PD, buck-boost controller, and battery charger. Get to know the related prototyping kit - its composition and functions.
The document further discloses how to set up different demos such as
* fixed output voltage in sink mode
* source mode operation
* 5-cell battery charging with/without battery cell monitoring.
You will also get a step-by-step guidance on firmware configuration via the proprietary ModusToolbox™ software.
This application note is a MUST-READ for engineers / designers who want to use USB-C PD to sink or source power in battery-powered applications.
EVAL_PMG1_B1_DRP kit guide
About this document
Scope and purpose
The EVAL_PMG1_B1_DRP is an evaluation kit for the EZ-PD™ PMG1-B1 USB Power Delivery (PD) microcontroller (MCU) with an integrated buck-boost battery charger. EZ-PD™ PMG1-B1 is targeted for battery-powered applications that are powered by USB-C PD such as cordless power tool chargers, wireless speakers, and portable electronics. EZ-PD™ PMG1 (Power Delivery Microcontroller Gen1) is a portfolio of high-voltage USB-C PD microcontrollers. These MCUs include Arm® Cortex® CPU core, USB-C PD controller, and configurable integrated analog and digital peripherals. EZ-PD™ PMG1-B1 is targeted at embedded systems that power from USB-C port and need an MCU to implement the product features.
Intended audience
This document is intended for designers who want to Sink or Source power through the USB-C PD port in applications such as the cordless power tool charger, wireless speakers, and portable electronics. The kit can be used to sink up to 100 W and source up to 27 W. The kit can also be used to charge 2 cell-5 cell batteries, and the battery charging algorithm is implemented as part of PMG1-B1 SDK in ModusToolbox™ software.
