3D Magnetic Sensor 2 Go Kit for the TLV493-A1B6
This article evaluates the MS2GO kit, a cost-effective way of evaluating the suitability and performance of the Infineon XENSIV TLV493-A1B6 measurement sensor.
The Infineon TLV493-A1B6 is a 3D measurement magnetic sensor that is widely used in commercial applications. This development tool allows users to become familiar with 3D magnetic sensors and measure them for product evaluation. For those interested in evaluating its functionality and performance, Infineon also offers a budget-friendly, plug-and-play Magnetic Sensor 2 Go kit engineered to allow users to explore and test the TLV493-A1B6.
Figure 1: From designing game controllers to engineering mobile camera lens positioning systems, the Infineon TLV493D-A1B6 MS2GO can speed up development and troubleshooting. (Source Pixabay)
Background on the Infineon TLV493-A1B6
The Infineon TLV493-A1B6 is part of the XENSIV product family of 3D magnetic sensors that utilize a board mount Hall effect magnetic sensor for 3D measurement. It is packaged with a small 6-pin, which can provide an accurate three-dimensional sensor and low power consumption. These sensors can be used to replace both potentiometer and optical solutions, and the TLV493-A1B6 was specifically designed for use with consumer devices. The main application includes joystick, control elements, multifunction knobs, electronic meters, and other applications requiring accurate 3D measurement and low power consumption.
Figure 2: The Infineon Technologies TLV493D-A1B6 works well in a wide variety of applications and environments, including tamper-proof e-meters. (Source Bigstock)
The TLV493-A1B6 is capable of non-contact linear, 3D, and rotational movement using lateral and vertical Hall plates. It offers high-temperature stability and is both robust and small, making it ideal for more accurate system designs. In addition, the TLV493-A1B6 offers five different power modes, including an ultra low power mode that only requires 10µA of current.
The 3D Magnetic Sensor 2GO Kit for the TLV493D-A1B6
Figure 3: The Infineon Technologies TLV493D-A1B6 MS2GO is designed to allow engineers to evaluate the capabilities of the TLV493D-A1B6 3D measurement sensor. (Source Mouser)
The 3D Magnetic Sensor 2 Go Kit (made by Infineon) is engineered for evaluating the TLV493D-A1B6 sensor. This budget-priced evaluation kit (which includes a GUI available as a free download) is an excellent tool for fast and easy plug-and-play systems. In fact, among the key features of the TLV493D-A1B6 MS2GO is the ability to take measurements within minutes due to its plug-and-play capabilities and its power over Micro USB.
Figure 4: Infineon offers several add-on components and adapters for use with the TLV493D-A1B6 MS2GO to support its plug-and-play capabilities as well as evaluation and prototyping. (Source Infineon)
It includes a complete set of onboard devices, including the J-Link Lite Debugger (via a XMC4200 Microcontroller) on a ready-to-use printed circuit board (PCB). This 2GO Kit also includes a 3D Hall sensor and a 7x7x5 mm ferrite block magnet; in addition, there are also adapters available (e.g., rotation knobs, joysticks, rotation linear sliders, out-of-shaft angle adapters) that can be directly mounted onto the 2GO kit.
Figure 5: Among the adapters available for TLV493D-A1B6 MS2GO Kit is the linear slider adapter that can be directly mounted on the sensor 2GO Kits. (Source Infineon)
This MS2GO evaluation kit has an XMC1100 (ARM® Cortex™-M0 based) CPU and includes voltage regulation, ESD, and reverse current protection. It is a small (50mm x 14 mm) 6-pin package that features low power consumption (ultra-low power mode) a standard 2-wire digital I²C interface.
Applications for the Infineon TLV493-A1B6 and the MS2GO Kit
The Infineon TLV493-A1B6 is ideal for use in e-meters, mobile camera lens position sensing for actions such as zoom and focus, measuring 360° angle rotation related to shafts (for end of shaft and out of shaft), and joystick movement (including thumb, finger, and gaming paddles). It can also be used with control elements such as knobs and sliders as well as linear slide movement.
Figure 6: The Infineon Technologies TLV493D-A1B6 sensor is ideal for many applications, including sliders, knobs, and buttons for everyday commercial products. (Source Bigstock)
The 2GO kit allows engineers to quickly evaluate the suitability of the TLV493-A1B6 for a design or application, which can save significant time during the application and product development phase. This kit can prove invaluable during product testing and evaluation, and its debugging capabilities allow many potential issues to be worked out before a prototype is even made.
The MS2Go Kit: A Cost-Effective Evaluation Solution
For commercial applications requiring a 3D magnetic sensor, the MS2GO kit is a cost-effective way of evaluating the suitability and performance of the Infineon XENSIV TLV493-A1B6 measurement sensor. The kit includes everything needed to start obtaining measurements within minutes and an onboard J-Link Lite Debugger with an embedded RM® Cortex™-M0 based CPU to support debugging and troubleshooting.
Infineon TLV493-A1B6 Giveaway Opportunity
Click HERE to view our All About Circuits quiz and giveaway page, which takes a more in-depth look at the instructions for being entered to win an Infineon Technologies TLV493D-A1B6 MS2GO Evaluation Board (Giveaway ends 5/30/21).
