ADI LTC6363 Low Power Differential Amplifiers | New Product Brief
Analog Devices LTC6363 family of high-precision, low-power differential amplifiers have rail-to-rail outputs with linearity and noise optimized to drive high-resolution SAR ADCs.
ADI LTC6363 Differential Amplifiers
LTC6363 amplifiers are available in variants with the gain set by external resistors or with fixed gain using precision laser-trimmed on-chip resistors. The devices have low input-referred noise, offset voltage, gain error and drift, as well as a high common mode rejection for high-precision applications.
The amplifiers have a typical active current consumption of 1.7mA at 3V and 20µA in shutdown mode, enabling use in battery-powered applications. LTC6363 amplifiers can operate from a 2.8V to 11V supply and are available in compact MSOP and DFN packages.
- Rail-to-rail outputs optimized to drive SAR ADCs
- User-set gain or fixed gain options
- Fixed gain set by precision laser-trimmed on-chip resistors
- 2.9nV/√Hz input-referred noise
- 45ppm maximum gain error, 0.5ppm/°C maximum gain error drift
- 94dB minimum CMRR
- 1.7mA active supply current (VS = 3V)
- 20µA (VS = 3V) low power shutdown
- 2.8V (±1.4V) to 11V (±5.5V) supply voltage
- 8-lead MSOP
- 2mm x 3mm 8-lead DFN
