Amphenol ICC ix Industrial™ IP20 Connectors | Tech Specs
October 09, 2020 by TTI, IncThis episode of Tech Specs is part of a video series highlighting the features, applications, and technical specs of newly-released products.
Amphenol ICC ix Industrial connectors support 10 gig ethernet and PoE, but they have a 10mm pitch and are 75% smaller than a regular RJ45 connector. This lets you increase port density without sacrificing performance.
The connectors also have 2-point metal latches that prevent accidental disconnection in high vibration applications, while heavy-duty solder tabs keep the connector firmly attached to the PCB. ix Industrial connectors offer 360 degree shielding for robust EMI immunity in electrically noisy environments.
They can also be used for signal and bus connections or other interfaces with keyed housings to ensure proper installation.
- 10 position connector with Cat6A 10GBASE-T performance and PoE capability
- 10mm pitch and 75% smaller than RJ45 for greater port density
- 2-point metal latching prevents accidental disconnection
- Heavy duty shield solder hold-down tabs on PCB mount receptacles
- 360° shielding through mated pair for excellent noise immunity
- Keyed housings (Type-A, -B, -C) for Ethernet, Signal/Bus, and other ports
Click here for more information.
