AVX 00-6791 RF Coaxial IDC Connectors | New Product Brief
May 21, 2019 by Mouser ElectronicsAVX 6791 series RF Coaxial IDC Connectors are compact and enable fast termination of coaxial cables at a lower cost than conventional termination options and are ideal for space-constrained automotive and industrial designs.
The connectors can be used with signals up to 6 gigahertz and are rated for up to 0.5 amps and 125 volts, making them ideal for common wireless protocols. These connectors also feature an easy assembly process that can be automated to reduce cost and eliminate hand soldering.
The 6791 series is available for multiple cable sizes and has a seated height as low as 3.9 millimeters. They are also mechanically robust, with a peel off force up to 70 newtons and an operating temperature range from negative 40 to positive 105 degrees celsius.
- Supports signals up to 6GHz
- Current Rating: 0.5A (cable dependent)
- Voltage Rating: 125VAC
- Easy assembly process with ability to automate
- Supports cables with outer jacket diameter from 2.33mm to 3.10mm
- Minimum dimensions: 10mm x 6.6mm x 3.9mm (L x W x H, seated)
- Peel-off force: 70N horizontal, 20N vertical
- Operating temperature range: -40°C to +105°C
