AVX 9286-300 Thru Wire Connectors | New Product Brief
AVX 9286-300 series connectors are poke-home wire-to-wire connectors for heavier industrial wires and feature a smaller package than alternative solutions.
The series includes connectors for 12AWG to 18AWG solid or stranded wires, with ratings up to 15A and 600V. The connectors are easy to use, requiring a simple strip and poke-home insertion. The 9286-300 series uses a single-piece phosphor bronze contact with high force contact beams that provide a stable connection, while a center wire stop prevents over insertion.
AVX 9286-300 series connectors feature a glass-filled thermoplastic housing that is UL94 V-0 rated and measures as small as 17.5mm long by 6.0mm square, and it’s available in multiple colors to match wiring insulation colors for fast and easy assembly.
- Poke-Home connectors for 12AWG to 18AWG.
- Current rating up to 15A.
- Strip and poke-home wire insertion, twist and pull wire extraction.
- High force contact beams provide mechanical stability and wire retention.
- Integral wire stop prevents over insertion.
- UL94 V-0 glass-filled thermoplastic housings.
- Color-coded housings match wires for fast, easy assembly.
- Applications: industrial machine controls, commercial building, smart grid, solid state lighting.
