AVX F9H Tantalum Electrolytic Capacitors | New Product Brief
AVX F9H series are high-reliability solid tantalum electrolytic capacitors for use in applications such as automotive ECUs and industrial equipment.
AVX F9H series are high-reliability solid tantalum electrolytic capacitors for use in applications such as automotive ECUs and industrial equipment. The capacitors are AEC-Q200 compliant and have a very low failure rate of 0.5%/1000hrs. They offer an expanded temperature range, operating at up to 105°C at their rated voltage or up to 150°C with voltage derating, making them ideal for use in engine and transmission ECUs, starters, headlamps, and demanding industrial equipment. The F9H series is available with capacitance values from 10µF to 47µF with 10% or 20% tolerance and with 10V and 16V rated voltages. The J-lead surface-mount capacitors are available in case sizes that range from 1206 to 2312.
- AEC-Q200 compliant
- Low 0.5%/1000hrs failure rate
- -55°C to +150°C operating temperature range, up to +105°C without derating
- Capacitance values: 10µF to 47µF, 10% or 20% tolerance
- Voltage ratings: 10V, 16V
- Package: SMD J-lead in 1206, 1210, or 2312 case sizes
