BEL GROUP Open Frame Power Supplies | New Product Brief
Bel Power Solutions ACC600 and MCC600 open frame power supplies are high density, high-efficiency power supplies for instrumentation, lighting, medical, and industrial applications.
The power supplies operate from a wide universal input and output up to 600W with convection cooling, and support current sharing for parallel operation. Output voltage options range from 12V to 58V, with a separate 5V standby supply available. The supplies operate at up to 93% efficiency and have no-load power consumption as low as 3W.
ACC600 and MCC600 power supplies are compact, measuring just 127mm x 216mm x 41mm. The MCC600 is designed and approved to the latest medical standards, providing 2 x MOPP isolation for Class I & Class II applications.
- Input Voltage:
- 85VAC to 264VAC, 47Hz to 63Hz
- 120VDC to 390VDC input voltage
- 600W output power
- Current sharing with up to 3 supplies in parallel
- Output voltage: 12V, 15V, 24V, 30V, 48V, 58V
- 5V standby supply option
- Efficiency: up to 93%
- Dimensions: 127mm x 216mm x 41mm
- MCC600 designed and approved to EN/IEC 60601-1
