Cypress Semiconductor EZ-PD Barrel Connector Replacement | New Product Brief
Cypress Semiconductor’s EZ-PD Barrel Connector Replacement kit allows designers to quickly convert designs powered with a legacy barrel connector or USB micro-B to being powered via USB-C.
The EZ-PD BCR kit is based on the EZ-PD BCR IC, which is a highly-integrated and pre-programmed USB-C port controller that is USB PD 3.0 certified and supports Programmable Power Supply mode. A rotary switch on the board adjusts the output voltage from 5V to 20V, while resistor dividers set the current limit and can be adjusted to supply up to 5A for power delivery up to 100W.
The IC is housed in a 24-pin QFN package and requires minimal external components, with the kit PCB measuring just 3.7cm x 2.5cm.
- Easily replace legacy barrel connectors (up to 100W) or USB micro-B connectors
- USB PD 3.0 certified, including Programmable Power Supply (PPS) mode
- VBUS selectable via a rotary switch: 5V, 9V, 12V, 15V, or 20V
- Current limit set by resistor dividers, adjustable up to 5A
- EZ-PD BCR ID: 24-pin QFN package and minimal external components
- Kit PCB size: 3.7cm x 2.5cm
