Harwin Archer Kontrol IDC | New Product Brief
Harwin Archer Kontrol IDC Cable Connectors
Harwin Archer Kontrol IDC Cable Connectors and Cable Assemblies are designed to provide fast, reliable connections using a fine 0.635mm pitch ribbon cable without the use of special tooling.
With a position count from 12 to 80 positions, these connectors offer a 0.5 amp per contact current rating, 500 Volts AC maximum voltage, and an operating temperature range of -20 to +105 degrees celsius.
The 1.27 mm pitch industrial connectors are for board-to-board and cable-to-board connections with both vertical and horizontal orientations. These connectors are capable of parallel board-to-board stacking heights of 8mm to 20mm.
With a durability of 500 cycles minimum, these IDC connectors are ideal for medium to high volume cable-to-board connections such as consumer electronics, industrial, lighting, and instrumentation systems.
