Harwin Gecko Screw-Lok Connectors | New Product Brief
Harwin Gecko Screw-Lok Connectors have ruggedized screw fixings for increased security in high vibration and high shock applications.
The captive stainless steel fixing hardware also resists corrosion caused by salt spray and humidity. The connectors have a 1.25mm pitch and are up to 45% smaller and 75% lighter than Micro-D connectors.
Screw-Lok connectors are easy to mate due to the “Mate-before-Lok” mechanism, which allows full mating of the connectors before engaging the screws. Male and female through-hole, surface mount, and cable connectors are available in through-hole or surface-mount variants with up to 50 contacts.
Individual contacts are rated for up to 2.8A, and the connectors can operate from -65°C to +150°C.
- Ruggedized screw fixings for increased security
- 20G vibration (10Hz to 2000Hz), 50G shock and acceleration
- Stainless steel hardware resists corrosion
- 1.25mm pitch
- Up to 45% smaller footprint than Micro-D
- Mate-before-Lok: connectors can be fully mated before engaging screws
- Variants: Cable, vertical through-hole, vertical surface-mount
- Male and female options for all
- Current rating:
- 2.8A individual contact
- 2A per contact (all contacts simultaneously)
- Operating temperature range: -65°C to +150°C
