Honeywell ABP2 Series Board Mount Pressure Sensors | Tech Specs
Honeywell's APB2 series of board mount pressure sensors provides 24-bit calibrated and compensated measurements with a low total error band.
Measurements are sent over serial interface with a sampling rate up to roughly 200 hertz, while lower sampling rates enable ultra-low power operation ideal for battery-powered devices. Sensors are available with a variety of supply voltages, pressure units and range, and with a plastic or metal pressure port.
They’re also available with a liquid media option that adds a silicone-based gel coating under the port for use with non-corrosive liquids.
- Digital output: 24-bit calibrated/compensated measurements from -40°C to 110°C
- Accurate: Total Error Band as low as ±1.5%FSS and ±0.25%FSS accuracy (BFSL)
- Interface: SPI or I2C
- Ultra-low power consumption: as low as 0.01mW average power, 1Hz sample rate
- Pressure Range: 4bar to 12bar, 400kPa to 1.2MPa, 60psi to 175psi
- Versatile: plastic or metal port, liquid media option for non-corrosive liquids/condensation
Click here for more information.
