MAXIM INTEGRATED MAX31825 1-Wire Temperature Sensor | New Product Brief
Maxim Integrated’s MAX31825 1-Wire® Temperature Sensor provide accurate temperature measurements and a flexible functionality in a compact package.
The sensor provides 8-bit to 12-bit temperature measurements from -45°C to +145°C with better than ±1.75°C accuracy, and better than ±1°C from 0°C to +70°C. Temperature measurements are sent to the host using the 1-Wire interface, which requires only one data line that can also be used to parasitically power the sensor. Each sensor has a unique 64-bit serial code to allow multiple sensors on the same 1-Wire bus, and two address pins provide 64 addresses to identify the senor’s location on a board with multiple MAX31825 sensors.
The MAX31825 also offers an alarm output with user-definable settings and is housed in a 6-bump wafer-level package.
- Measurement range: -45°C to +145°C
- Accuracy (-45°C to +145°C): better than ±1.75°C
- Accuracy (0°C to +70°C): better than ±1°C
- 1-Wire® Interface requires only one data line for communication
- Unique 64-bit serial code stored in an on-chip ROM
- Allows multiple sensors on the same 1-Wire bus
- Two address pins: 64 different addresses using external resistor and pin strapping
- Identify sensor’s physical location
- Alarm output for temperature fault detection
- User definable alarm settings
- Package: 6-bump WLP, 1.078mm x 1.348mm
