Molex 2.4/5GHz Balanced Flex and PCB Antennas
Molex 2.4/5GHz Balanced Flex and PCB Antennas are designed for fast and easy integration into devices with Wi-Fi and other protocols using the 2.4 GHz and 5 GHz bands. Antennas are available with side and center-fed micro-coax cables terminated with u.FL connectors, with cable lengths up to 300 mm for design flexibility, and double-sided adhesive for easy placement. They operate in both the 2.4 GHz and 5 GHz bands and provide balanced RF transmission independent of cable length variations. The antennas have an RF power rating of 2 W and achieve up to 85% total efficiency and 4.75 dBi peak gain. Molex 2.4/5GHz Balanced Flex and PCB Antennas can be used in home automation, streaming set top boxes, connected vehicles, and industrial connectivity.
- Connector: u.FL
- Cable Lengths: 50 mm to 300 mm
- Frequency Ranges (MHz): 2400-2483.5, 5150-5850
- RF Power: 2 W max
- Total Efficiency: up to >85%
- Peak Gain: up to 4.75 dBi
0 Comments Login
