Monolithic Power Systems mEZ Plug and Play Power Modules | New Product Brief
MPS’ mEZ Plug & Play DC/DC power modules are wide-input, high-efficiency power solutions in an easy-to-use module for a broad range of applications.
MPS’ mEZ Plug & Play DC/DC power modules are wide-input, high-efficiency power solutions in an easy-to-use module for a broad range of applications. Modules are available for step-down, step-up, USB, and PoE applications and leverage MPS’ best-in-class ICs. This saves designers the time spent on component selection, layout, manufacturing, and qualification, and in turn gives them an optimized, known-good solution, with extensive protections and up to 95% efficiency. mEZ modules are also up to 40% smaller than competing solutions and require fewer external components. The modules offer load current up to 10 A, and standard output voltages from 1 V to 15 V.
- Module Types: step-down, step-up, USB, PoE
- Protections: Over-/Under-Voltage, Over-Current, Over-Temperature
- Efficiency: up to 95%
- Load Current: Up to 10 A
- Step-down Output Voltage: 1, 1.2, 1.5, 1.8, 2.5, 3.3, 5 V
- Step-up Output Voltage: 2, 12, 15 V
