Neutrik NA2-IO-DLINE Line I/O to Dante Interface | New Product Brief
Neutrik’s NA2-IO-DLINE Line I/O to Dante Interface is a PoE-powered Dante adapter providing two inputs and outputs.
Neutrik’s NA2-IO-DLINE Line I/O to Dante™ Interface is a PoE-powered Dante adapter providing two inputs and outputs. Dante is a digital media networking solution that enables near-zero latency distribution of uncompressed audio over standard Ethernet networks. The NA2-IO-DLINE is a compact adapter that can simultaneously feed analog audio into the Dante network while also outputting audio from other sources to amplifiers, speakers, or other equipment.
The adapter features balanced XLR inputs and outputs and is built for harsh stage conditions, with lockable input and network connections, a sheet metal housing, and removable rubber protectors. The adapter can be powered by a PoE switch or compliant PoE injector and consumes just 2W.
- Dimensions: 164mm x 82mm x 51mm (with rubber protection)
- Network connection: RJ45, 100BASE-TX, PoE support
- Built for harsh stage conditions
- Audio I/O: 2x lockable balanced XLR inputs, 2x balanced XLR outputs
- Sheet metal enclosure, removable rubber protectors, lockable connectors
- Power consumption: 2W
