New Product
ON Semiconductor’s NCP81239 4-Switch Buck-Boost Controller | New Product Brief
June 21, 2017 by Mouser Electronics
ON Semiconductor’s NCP81239 is a 4-switch buck-boost converter for use as a USB Power Delivery controller in computing and entertainment devices, displays, consumer electronics, and chargers.
ON Semiconductor’s NCP81239 is a 4-switch buck-boost converter for use as a USB power delivery controller in computing and entertainment devices, displays, consumer electronics, and chargers. The NCP81239 has a 4.5 V to 28 V input and load range and drives 4 nMOSFET switches to provide the correct output voltage in either the provider or consumer role.
The controller uses two independent current sense inputs and dual edge current mode control to detect and smoothly transition between buck and boost operation. In addition to USB PD, the NCP81239 supports quick charge 2.0 and 3.0 profiles and uses a dynamically programmed switching frequency from 150 kHz to 1.2 MHz.
  • Controlled slew rate voltage transitioning
  • Real time power good indication
  • Dead battery power support
  • Interface: I2C (two addresses available)
  • Protections: over-voltage, over-current, over-temperature
  • Package: 5 mm x 5 mm QFN32
More Information
