Samtec mPower 2mm UMPT/UMPS Ultra Micro Power Connectors | New Product Brief
April 19, 2019 by Mouser ElectronicsSamtec mPower™ 2mm Ultra Micro-Power Terminal and Ultra Micro-Power Socket Power Connectors are a flexible high power solution for power-only or signal and power applications.
Samtec mPower 2mm Ultra Micro Power Connectors
The 2.00mm pitch connectors can carry up to 18A per blade and are available with 2 to 5 positions. Stacking heights range from 5mm to 16mm, allowing designers to pair the mPower connectors with a variety of Samtec high speed connectors for unique and flexible power and signal system.
UMPT and UMPS connectors are offered with tin or gold-plated contacts as well as optional through-hole weld pads and a polyamide pad for use in pick-and-place assembly. The connectors have an operating temperature range as high as 125°C.
- Current Rating: Up to 18A per blade
- Position Counts: 2, 3, 4, or 5
- Stack Heights: 5mm to 16mm (up to 20mm in development)
- Use with Samtec high-speed connector systems for a unique power/signal system
- Plating: Matte tin or gold-plated power blades
- Operating Temperature: -55°C to +105°C (tin) / +125°C (gold-plated)
