New Product
SAMTEC SEARAY SEAF & SEAM Connectors | New Product Brief
July 10, 2019 by Mouser Electronics
These high-speed, high-density connectors provide designers the flexibility to address high-performance protocols.
SAMTEC SEARAY SEAF and SEAM connectors are high-speed, high-density and provide designers the flexibility to address 100GbE, Fibre Channel, and other high-performance protocols. The connectors support up to 56Gbps PAM4 and feature a 1.27mm pitch with Samtec’s Differential Vias™ technology for a simpler breakout region and wider routing channels.
Connectors are available with up to 560 positions, and the open-pin-field design can be used simultaneously for differential pairs, single-ended signals, and power. SEARAY connectors use Samtec’s rugged EdgeRate contact system, offering increased durability, low insertion force, and zippered unmating.
Connectors are available in vertical and right-angle configurations with stacking heights from 7mm to 18.5mm and in press-fit variants.
  • 56Gbps PAM4 performance
  • 1.27mm (0.050”) pitch grid
  • Up to 560 position open-pin-field
  • Differential pairs, single-ended signals, and power in the same interconnect
  • Rugged EdgeRate® contact system
  • Vertical and right-angle configurations
  • 7mm to 18.5mm stack heights
  • Solder or press-fit leads
More Information
