Schurter 400VDC IEC Connector System | New Product Brief
Discover how this system is ideal for power distribution units and data center equipment.
Schurter’s GP21 plug and GS21 socket-outlet are a safe and reliable interconnect system for 400VDC applications, including power distribution units and other data center equipment.
The connectors are UL approved and designed according to IEC TS 62735-1. They can carry a max load of 2.6kW and are hot-plug rated for disconnecting under max load. The GP21 rewireable plug accommodates 0.75mm2 to 1.5mm2 wires with screw terminals. The GS21 is a panel-mount snap-in socket-outlet offered with quick-connect or PCB terminals and compatible with cord retention systems.
The connector system is IP20 rated and can operate at temperatures from -5°C to +105°C.
- Standard form according to IEC TS 62735-1
- Ratings: 6.5 - 8.8A / 400 - 294VDC, max power 2.6kW
- Hot-plug disconnect under load up to 2.6kW
- GP21 rewireable plug
- Wire size: 0.75-1.5mm², 18AWG-16AWG
- Cable diameter: 6.4mm to 9.2mm
- GS21 socket-outlet
- Panel mount: 1.5mm to 2.0mm panel thickness
- Terminals: Quick-connect or PCB
- IP20 rating
- -5°C to +105°C operating temperature
