Stewart Connector’s SealJack RJ45 Jacks
Stewart Connector’s SealJack RJ45 jacks are designed for IP67 applications requiring high-speed communication. SealJack RJ45 jacks use a sealed design and are available in single- or four-port vertical configurations with a gasket that allows for front or rear panel mounting. The connectors support ethernet speeds up to 10 gigabits per second and are made from a nickel-plated die cast zinc with a design that minimizes the weight, volume, and area of the connector.
SealJack RJ45 jacks are POE+ compatible, available with or without LED indicators, and are ideal for rugged computing, industrial, military, marine, and renewable energy applications.
- Data Transmission: Supports 10/100 Base-T, 1G Base-T, 10G Base-T
- Port Density: 2.3 ports/in3
- Mating Cycles: 750 minimum
- Optional EPP 918-A protective coating
- Dimensions:
- Single port: 0.842 in x 1.093 in x 0.765 in
- Four port: 2.744 in x 1.093 in x 0.765 in
0 Comments Login
