TRACO Power TDN Series DC/DC Converters | New Product Brief
TRACO Power’s TDN series of high-performance DC/DC converters are available with up to 5 W outputs in compact DIP or SMD packages for high power density.
TRACO Power’s TDN series of high-performance DC/DC converters are available with up to 5 W outputs in compact DIP or SMD packages for high power density. The package for both the SMD and DIP variants measures just 13.2 x 9.1 x 10.2 mm for a total volume of just 1.23 cm3, allowing it to fit in small spaces while still providing accurate and tight output regulation.
TDN series converters provide fully regulated outputs with remote on/off control in single or dual output configurations. The converters are designed to operate over very wide inputs from their nominal rating and provide 1500 VDC isolation from input to output as well as short circuit protection with automatic recovery.
- Inputs: 9 VDC, 24 VDC, 48 VDC, all with 4:1 voltage range
- Outputs: 3.3 VDC to 24 VDC (single), ±5 VDC, ±12 VDC, ±15 VDC
- Efficiency: up to 84%
- Regulation
- Input Variation: 0.2% max
- Load Variation 0-100%: 1% max
- Cross regulation (dual output): 5% max
