United Chemi-Con Aluminum Electrolytic Capacitors HXC Series | Tech Specs
The United Chemi-Con’s HXC Series of capacitors can handle their rated ripple current for 4000 hours at 125°C, and they can also offer long life in high temperature and high humidity environments. They provide high reliability and high voltage together through a hybrid electrolyte design. They’re rated for voltages from 16 to 63 Volts DC and range in capacitance from 6.8 to 470 microfarads. Capacitors are available for ripple currents up to 2.1 amps RMS and with ESR as low as 18 milliohms. HXC series capacitors are AEC-Q200 compliant and can withstand temperatures from negative 55 to positive 125 degrees Celsius.
- Endurance with ripple current: 4000 hours at 125°C
- 2000 hours at 85°C/85% RH
- Hybrid electrolyte enables high reliability at high voltage
- Voltage range: 16VDC to 63VDC
- Capacitance range: 6.8µF to 470µF
- Ripple current: up to 2.1ARMS (125°C, 100kHz)
- Low ESR: down to 18mΩ
- AEC-Q200 compliant
- Temperature range: -55°C to +125°C
