Vishay NTC Thermistors, Standard Lug Sensors | Tech Specs
August 27, 2020 by TTI, IncThis episode of Tech Specs is part of a video series highlighting the features, applications, and technical specs of newly-released products.
Vishay’s NTCALUG01T thermistors are AEC-Q200 qualified NTC thermistors with a ring tongue terminal.
The thermistor chip is soldered to lead wires, insulated with an epoxy coating, then attached to the ring lug. The construction is extremely rugged and provides long term stability at 150°C, and the ring lug makes it easy to install, with options for M3 or M3.5 screws.
This also provides a high insulation voltage, making it ideal for high power EV inverters. The thermistor has a resistance of 10 kilo-ohms, and the lead wires are silver plated copper with ETFE insulation for durability in extreme environments.
For added value, this product can be customized to meet specific requirements.
- AEC-Q200 qualified (grade 1)
- Rugged construction: epoxy insulated sensor attached to a ring lug via a middle buffer layer
- 150°C long term stability (5000 hours dry heat)
- Insulation voltage: 2700VAC
- Resistance value at 25°C: 10kΩ
- Lead wires: 40mm to 500mm standard lengths, ETFE insulation, 3.4kV cable test voltage
Click here for more information.
