PARTS AND MATERIALS
Household light switches are a bargain for students of basic electricity. They are readily available, very inexpensive, and almost impossible to damage with battery power. Do not get “dimmer” switches, just the simple on-off “toggle” variety used for ordinary household wall-mounted light controls.
CROSS-REFERENCES
Lessons In Electric Circuits, Volume 1, chapter 1: “Basic Concepts of Electricity”
LEARNING OBJECTIVES
SCHEMATIC DIAGRAM
ILLUSTRATION
INSTRUCTIONS
Build a one-battery, one-switch, one-lamp circuit as shown in the schematic diagram and in the illustration.
This circuit is most impressive when the wires are long, as it shows how the switch is able to control circuit current no matter how physically large the circuit may be.
Measure voltage across the battery, across the switch (measure from one screw terminal to another with the voltmeter), and across the lamp with the switch in both positions.
When the switch is turned off, it is said to be open, and the lamp will go out just the same as if a wire were pulled loose from a terminal.
As before, any break in the circuit at any location causes the lamp to immediately de-energize (darken).
RELATED WORKSHEETS:
by Steve Arar
by Robert Keim
by Steve Arar
by Rushi Patel
