PARTS AND MATERIALS
CROSS-REFERENCES
Lessons In Electric Circuits, Volume 3, chapter 8: “Positive Feedback”
Lessons In Electric Circuits, Volume 4, chapter 3: “Logic Signal Voltage Levels”
LEARNING OBJECTIVES
SCHEMATIC DIAGRAM
Schmitt Triggers have a convention to show a gate that is also a Schmitt Trigger.
The same schematic redrawn to reflect this convention looks something like this:
ILLUSTRATION
INSTRUCTIONS
The 555 timer is probably one of the more versatile “black box” chips. Its 3 resistor voltage divider, 2 comparators, and built-in set-reset flip-flop are wired to form a Schmitt Trigger in this design.
It’s interesting to note that the configuration isn’t even close to the op-amp configuration shown elsewhere, but the end result is identical.
Try adjusting the potentiometer until the lights flip states, then measure the voltage.
Compare this voltage to the power supply voltage. Adjust the potentiometer the other way until the LED’s flip states again, and measure the voltage.
How close to the 1/3 and 2/3 marks did you get?
Try substituting the 9V battery with a 6-volt battery, or two 6 volt batteries, and see how close the thresholds are to the 1/3 and 2/3 marks.
Schmitt Triggers are a fundamental circuit with several uses. One is signal processing, they can pull digital data out of some extremely noisy environments.
Other big uses will be shown in following projects, such as an extremely simple RC oscillator.
THEORY OF OPERATION
The defining characteristic of any Schmitt Trigger is its hysteresis. In this case, it is 1/3 and 2/3 of the power supply voltage, defined by the built-in resistor voltage divider on the 555.
The built-in comparators C1 and C2 compare the input voltage to the references provided by the voltage divider and use the comparison to trip the built-in flip-flop, which drives the output driver, another nice feature of the 555.
The 555 can drive up to 200ma off either side of the power supply rail, the output driver creates a very low conduction path to either side of the power supply connections.
The circuit “shorts” each side of the LED circuit, leaving the other side to light up.
The 5KΩ resistors are not very accurate. It is interesting to note that IC fabrication doesn’t generally allow precision resistors, but the resistors compared to each other are extremely close in value, which is critical to the circuit’s operation.
by Luke James
by Robert Keim
by Jake Hertz
