The circuit shown here is a four-bit analog-to-digital converter (ADC). Specifically, it is a flash converter, so named because of its high speed:
Explain why we must use a priority encoder to encode the comparator outputs into a four-bit binary code, and not a regular encoder. What problem(s) would we have if we were to use a non-priority encoder in this ADC circuit?
I won’t directly answer this question, but instead pose a “thought experiment.” Suppose the analog input voltage (Vin) were slowly increased from 0 volts to the reference voltage (Vref). What do the outputs of the comparators do, one at a time, as the analog input voltage increases? What input conditions does the encoder see? How would a primitive “diode network” type of encoder (which we know does not encode based on priority) interpret the comparator outputs?
Here, I show students a very practical application of a priority encoder, in which the necessity of priority encoding should be apparent after some analysis of the circuit.
Predict how the operation of this “flash” analog-to-digital converter (ADC) circuit will be affected as a result of the following faults. Consider each fault independently (i.e. one at a time, no multiple faults):
For each of these conditions, explain why the resulting effects will occur.
The purpose of this question is to approach the domain of circuit troubleshooting from a perspective of knowing what the fault is, rather than only knowing what the symptoms are. Although this is not necessarily a realistic perspective, it helps students build the foundational knowledge necessary to diagnose a faulted circuit from empirical data. Questions such as this should be followed (eventually) by other questions asking students to identify likely faults based on measurements.
This “flash” ADC circuit has a problem. The output code jumps from 0000 to 1111 with just the slightest amount of input voltage (Vin). In fact, the only time it outputs 0000 is when the input terminal is slightly negative with reference to ground:
Identify at least two possible component faults that could cause this problem, and explain your reasoning in how you made the identifications.
One possible fault is that resistor R16 has failed open, but this is not the only possibility.
Have your students explain their reasoning in class to you, so that you may observe their diagnostic thought processes.
Don’t just sit there! Build something!! |
Learning to analyze digital circuits requires much study and practice. Typically, students practice by working through lots of sample problems and checking their answers against those provided by the textbook or the instructor. While this is good, there is a much better way.
Always be sure that the power supply voltage levels are within specification for the logic circuits you plan to use. If TTL, the power supply must be a 5-volt regulated supply, adjusted to a value as close to 5.0 volts DC as possible.
Let the electrons themselves give you the answers to your own “practice problems”!
Students don’t just need mathematical practice. They also need real, hands-on practice building circuits and using test equipment. So, I suggest the following alternative approach: students should build their own “practice problems” with real components, and try to predict the various logic states. This way, the digital theory “comes alive,” and students gain practical proficiency they wouldn’t gain merely by solving Boolean equations or simplifying Karnaugh maps.
Another reason for following this method of practice is to teach students scientific method: the process of testing a hypothesis (in this case, logic state predictions) by performing a real experiment. Students will also develop real troubleshooting skills as they occasionally make circuit construction errors.
I highly recommend CMOS logic circuitry for at-home experiments, where students may not have access to a 5-volt regulated power supply. Modern CMOS circuitry is far more rugged with regard to static discharge than the first CMOS circuits, so fears of students harming these devices by not having a “proper” laboratory set up at home are largely unfounded.
A comparator may be thought of as a one-bit analog-to-digital converter:
Explain why this description of a comparator is appropriate. What exactly is meant by the term “analog-to-digital converter,” or ADC?
All ADCs input one or more analog signals and output a discrete signal.
This description of a comparator is not just theoretical. In many practical ADC circuits, a comparator is actually used as the primary analog-to-digital conversion device. This is particularly true for oversampling or Sigma-Delta converters, which may be built around a single (1-bit) comparator.
Flash analog-to-digital converters are easy to understand, but are not practical for many applications. Identify some of the drawbacks of the “flash” circuit design.
Flash converter circuits have too many components! Actually, the answer is a bit more detailed than this, but easy enough to find on your own that I’ll leave the task of research to you.
It is a shame that flash converter circuits suffer the disadvantage(s) that they do. They are so simple to understand and have such an inherent speed advantage over other circuit designs! Discuss with your students why the weaknesses of the flash design make the other ADC types necessary, and even preferable in most applications.
Explain the operating principle of this analog-to-digital converter circuit, usually referred to as a tracking converter:
The binary counter will count up or down as necessary to “track” the analog input voltage, resulting in a binary output that continuously represents the input.
Follow-up question: this form of ADC is not very effective at following fast-changing input signals. Explain why.
Have your students express the answer to this question in their own words, not just copying the answer I provide. Aside from the flash converter, the tracking converter is one of the easiest ADC circuits to understand.
Explain the operating principle of this analog-to-digital converter circuit, usually referred to as a successive-approximation converter:
Note: the successive-approximation register (SAR) is a special type of binary counting circuit which begins counting with the most-significant bit (MSB), then the next-less-significant bit, in order all the way down to the LSB. At that point, it outputs a “high” signal at the “Complete” output terminal. The operation of this register may be likened to the manual process of converting a decimal number to binary by “trial and fit” with the MSB first, through all the successive bits down to the LSB.
The successive approximation register counts up and down as necessary to “zero in” on the analog input voltage, resulting in a binary output that locks into the correct value once every n clock cycles, where n is the number of bits the DAC inputs.
Follow-up question: this form of ADC is much more effective at following fast-changing input signals than the tracking converter design. Explain why.
Explain the operating principle of a single-slope ADC circuit, in your own words.
I won’t give away all the details here, but the single-slope converter uses an integrator and a binary counter, the binary output determined by how long the counter is allowed to count.
Tutorials abound on simple ADC strategies, so your students should have little problem locating an adequate explanation for the operation of a single-slope ADC.
Explain the operating principle of a dual-slope ADC circuit, in your own words.
I won’t give away all the details here, but the dual-slope converter uses the same integrator and binary counter that the single-slope ADC does. However, the integrator is used a bit differently in the dual-slope design, the benefits being greater immunity to high-frequency noise on the input signal and greater accuracy due to relative insensitivity to integrator component values.
Tutorials abound on simple ADC strategies, so your students should have little problem locating an adequate explanation for the operation of a dual-slope ADC.
The Delta-Sigma or Sigma-Delta analog-to-digital converter works on the principle of oversampling, whereby a low-resolution ADC repeatedly samples the input signal in a feedback loop. In many cases, the ADC used is nothing more than a comparator (a 1-bit ADC!), the output of this ADC subtracted from the input signal and integrated over time in an attempt to achieve a balance near 0 volts at the output of the integrator. The result is a pulse-density modulated (PDM) “bitstream” of 1-bit digital data which may be filtered and decimated (converted to a binary word of multiple bits):
Explain what this PDM bitstream would look like for the following input voltage conditions:
In order to answer this question, students must have a good grasp of how the summing integrator works. Discuss with them how the feedback loop’s “goal” is to maintain the integrator output at the reference voltage (Vref), and how the 1-bit ADC can only make adjustments to the integrator’s output by driving it upward or downward by the same analog quantity every clock pulse.
The pulse-density modulation (PDM) of a 1-bit oversampled Delta-Sigma modulator circuit may be “decimated” into a multi-bit binary number simply by counting the number of “1” states in a bitstream of fixed length.
Take for example the following bitstreams. Sample the first seven bits of each stream, and convert the equivalent binary numbers based on the number of “high” bits in each seven-bit sample:
Then, take the same five PDM bitstreams and “decimate” them over a sampling interval of 15 bits.
Sampling interval = 7 bits
Sampling interval = 15 bits
Follow-up question: what relationship do you see between sampling speed and resolution in this “decimation” process, and how does this relate to the performance of a Delta-Sigma ADC?
With little effort, your students should be able to see that sampling twice as many bits in the PDM bitstream adds one more bit of resolution to the final binary output. Such is the nature of so many circuits: that optimization of one performance parameter comes at the expense of another.
Students may question how two (or more!) different decimation results can occur from the same bitstream, especially as shown in the answer for the 7-bit groupings. The answer is two-part: first, the bitstreams I show are not all perfectly repetitive. Some change pattern (slightly) mid-way, which leads to different pulse densities in different sections. The second part to this answer is that the nature of decimation by grouping will inevitably lead to differing results (even when the pattern is perfectly repetitive), and that this is the converter’s “way” of resolving an analog quantity lying between two discrete output states. In other words, a pair of decimated values of “4” and “5” (1002 and 1012, respectively) from a perfectly repetitive bitstream suggests an analog value lying somewhere between the discrete integer values of “4” and “5”. Only by sampling groups of bits equal to the period of the PDM repetition (or integer multiples of that repetition) can the digital output precisely and constantly equal the analog input.
Suppose an analog-digital converter IC (“chip”) inputs a voltage ranging from 0 to 5 volts DC and converts the magnitude of that voltage into an 8-bit binary number. How many discrete “steps” are there in the output as the converter circuit resolves the input voltage from one end of its range (0 volts) to the other (5 volts)? How much voltage does each of these steps represent?
This ADC (Analog-to-Digital Converter) circuit has 256 steps in its output range, each step representing 19.61 mV.
This question is not so much about ADC circuitry as it is about digital resolution in general. Any digital system with a finite number of parallel bits has a finite range. When representing analog variables in digital form by the limited number of bits available, there will be a certain minimum voltage increment represented by each “step” in the digital output. Here, students get to see how the discrete nature of a binary number translates to real-life measurement “rounding.”
One of the idiosyncrasies of analog-to-digital conversion is a phenomenon known as aliasing. It happens when an ADC attempts to digitize a waveform with too high of a frequency.
Explain what aliasing is, how it happens, and what may be done to prevent it from happening to an ADC circuit.
As the saying goes, a picture is worth a thousand words:
The point of this question (and of the answer given) is to have students put this important concept into their own words.
Something noteworthy for students and instructors alike is that aliasing may be visually experienced using digital oscilloscopes. Setting the timebase (seconds/division) control too slow may result in a false (aliased) waveform displayed in the oscilloscope. Not only does this make a good classroom demonstration, but it also is a great lesson to learn if one expects to use digital oscilloscopes on a regular basis!
Analog-to-digital converter circuits (ADC) are usually equipped with analog low-pass filters to pre-condition the signal prior to digitization. This prevents signals with frequencies greater than the sampling rate from being seen by the ADC, causing a detrimental effect called aliasing. These analog pre-filters are thus known as anti-aliasing filters.
Determine which of the following Sallen-Key active filters is of the correct type to be used as an anti-aliasing filter:
The low-pass Sallen-Key filter, of course! What’s the matter? You’re not laughing at my answer. What I’m doing here is asking you to some research on Sallen-Key filters to confirm your qualitative analysis. And yes, I do expect you to be able to figure out which of the two filters is low-pass based on your knowledge of capacitors and op-amps, not just look up the answer in an op-amp reference book!
Discuss with your students various ways of identifying active filter types. What clues are present in these two circuits to reveal their filtering characteristics?
Suppose a particular ADC has an input voltage range of 5 volts to -5 volts, and therefore is suitable for digitizing AC input signals. A technician wants to use this ADC to digitize AC line voltage (120 volts RMS), and builds the following conditioning circuit to safely connect the ADC to the AC line:
Unfortunately, this ADC is not able to fully sample the AC waveform when tested. It “overflows” and “underflows” at the waveform’s peaks, as though the input waveform is too large (outside of the 5/-5 volt ADC chip range). The technician re-checks his calculations, but still thinks the voltage division ratio provided by the potential transformer and resistor network should be sufficient for this task.
What is wrong with this circuit? Why does it “over-range” at the waveform peaks instead of sampling the 120 volt waveform with range to spare? Then, once having identified the problem, recommend a solution to fix the problem.
The technician failed to consider the peak voltage of the AC line!
Challenge question: one thing the technician did right in this circuit was use a transformer as the front-end of his signal conditioning network. Explain why this was a smart idea. In other words, why would it possibly be worse to simply use a resistive voltage divider to do all the attenuation, instead of using a step-down transformer to do part of it and a resistive divider to do the rest?
The given answer is purposefully minimal, but should contain enough information that anyone familiar with RMS versus peak sinusoidal values should realize what the problem is. There is more than one practical solution for fixing this problem, so be sure to allow time for discussion into the various options.
This bar graph driver circuit takes an audio input signal and displays the amplitude as a moving “bar” of lights. The stronger the amplitude of the signal, the more LEDs energize in the bar graph display. Predict how the operation of this circuit will be affected as a result of the following faults. Consider each fault independently (i.e. one at a time, no multiple faults):
Follow-up question: does each comparator source or sink current to its respective LED?
Challenge question: if resistors R1 through R7 are all equal value, the response of the bar graph will be linear (twice the signal amplitude results in twice as many LEDs energized). What would have to be changed in this circuit to give the bar graph a logarithmic response, so it registered proportional to a decibel scale rather than a voltage scale?
Questions like this help students hone their troubleshooting skills by forcing them to think through the consequences of each possibility. This is an essential step in troubleshooting, and it requires a firm understanding of circuit function.
Examine this vertical (“bird’s eye”) view of a boat resisting a river’s current:
Suppose the driver of this boat does not own an anchor, and furthermore that the only form of propulsion is an electric “trolling” motor with an on/off switch (no variable speed control). With the right combination of switch actuations (on, off, on, off), it should be possible for the boat to maintain its position relative to the riverbanks, against the flow of water.
Now, if we know the boat is actually holding position in the middle of the river, by trolling motor power alone, the pattern of on/off switch actuations should tell us something about the speed of the river. Perform a couple of “thought experiments” where you imagine what the driver of the boat would have to do with the motor’s on/off switch to maintain position against a fast current, versus against a slow current. What relationship do you see between the switch actuations and the speed of the current?
Note: once you understand this question, you will be better prepared to grasp the operation of a Delta-Sigma analog-to-digital converter!
The duty cycle of the switch actuations is in direct proportion to the river’s speed.
The purpose of this question is to present an analogy which students may use to grasp the operation of a Delta-Sigma ADC: the idea that a bitstream (PDM) may represent an analog value.
by Jake Hertz
by Dale Wilson
by Jake Hertz
by Jake Hertz
