Don’t just sit there! Build something!! |
You will learn much more by actually building and analyzing real circuits, letting your test equipment provide the änswers” instead of a book or another person. For successful circuit-building exercises, follow these steps:
When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
Let the electrons themselves give you the answers to your own “practice problems”!
The characteristically colored glow from a gas-discharge electric light is the result of energy emitted by electrons in the gas atoms as they fall from high-level “excited” states back to their natural (“ground”) states. As a general rule of electron behavior, they must absorb energy from an external source to leap into a higher level, and they release that energy upon returning to their original level.
Given the existence of this phenomenon, what do you suspect might be occurring inside a PN junction as it conducts an electric current?
PN junctions emit energy of a characteristic wavelength when conducting current. For some types of PN junctions, the wavelengths are within the visible range of light.
Follow-up question: what practical application can you think of for this phenomenon?
The practical application of this phenomenon should be obvious, and it is very commonplace in modern electronic equipment. Discuss with your students the energy-efficiency of this light emission as compared to an incandescent lamp.
Explain the operating principle of a photovoltaic cell, otherwise known as a “solar cell.” What happens within these devices to convert sunlight directly into electricity?
The energy of photons (light “particles”) striking a PN semiconductor junction creates electron-hole pairs, which then move in the direction that the depletion region’s electric field pushes them.
Challenge question: of what significance is the band gap of the PN junction to the efficiency of the cell?
There is quite a bit of detail that could be added to the account given in the answer. Ask your students to supply some of this detail! There are many resources for learning how photovoltaic cells work, so your students should have no trouble finding the information on their own.
The nonconducting depletion region of a PN junction forms a parasitic capacitance between the P and the N semiconductor region. Does the capacitance increase or decrease as a greater reverse-bias voltage is applied to the PN junction? Explain your answer.
The junction capacitance will decrease as the reverse-bias voltage across the junction increases.
Challenge question: can you think of any practical applications for this variable-capacitance effect?
This question is a good review of capacitor theory, and also an opportunity to introduce a special kind of diode: the varactor.
Explain what a Schottky diode is, and how it differs in construction and in function from a normal semiconductor PN junction diode.
A Schottky diode, otherwise known as a hot carrier diode, is formed by a junction of metal and N-type semiconducting material. These diodes have less forward voltage drop, faster reverse-recovery time, more reverse leakage current, and less reverse voltage capability than regular PN junction diodes.
Ask your students if they happened to research any datasheets for Schottky diodes, and if they have parameters to compare against typical PN junction rectifying diodes such as the 1N400x series.
Draw the schematic symbol for a Schottky diode, and give some examples of typical applications for it.
I’ll let you research some of the typical applications of Schottky diodes.
Ask your students to explain why the applications of Schottky diodes are well suited for these diodes’ unique capabilities. What is it about the typical applications that make use of these diodes’ fast reverse-recovery times and/or low forward voltage drop?
Note to your students that the schematic symbol for a Schottky diode is easily confused with the schematic symbol for a zener diode. Pay close attention to the symbol!
There is a special type of diode called a varactor, which is used to create a voltage-dependent capacitance. This function is often used in electronic radio tuner circuits:
The voltage-dependent capacitance of this diode is given by the following equation:
Where,
CJ = Junction capacitance
Co = Junction capacitance with no applied voltage
V = Applied reverse junction voltage
Based on this equation, would you say that capacitance is directly or inversely related to the applied reverse-bias voltage of a varactor diode? Based on what you know of diode theory, explain why this makes sense.
Cj is inversely related to V for a varactor diode.
Follow-up question: substitute the varactor diode capacitance equation into the standard resonant frequency equation to arrive at one equation solving for frequency in terms of L and diode voltage V.
This question reinforces students’ understanding of the mathematical terms direct and inverse, as well as review basic PN junction theory and capacitor theory.
What type of diode is always packaged in a clear glass or plastic body (as opposed to an opaque plastic body)? Explain how the appearance of the component is helpful in determining its identity.
This is a nasty, trick question! The physical appearance of any semiconductor component is a poor indication of its identity. Many small zener diodes are packaged in clear bodies, but this does not mean all clear-bodied diodes are zeners, nor that all zeners are found in clear packages! The part number of a diode is the only reliable indicator of its identity.
Follow-up question: the physical size of a component is often an indication of what performance parameter?
I usually do not ask “trick” questions such as this, but occasionally they work really well to get the point across.
In Partnership with Allegro MicroSystems
by Aaron Carman
by Jeff Child
