Don’t just sit there! Build something!! |
Avoid using the model 741 op-amp, unless you want to challenge your circuit design skills. There are more versatile op-amp models commonly available for the beginner. I recommend the LM324 for DC and low-frequency AC circuits, and the TL082 for AC projects involving audio or higher frequencies.
As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistor values between 1 kΩ and 100 kΩ.
Let the electrons themselves give you the answers to your own “practice problems”!
Calculate the current through resistor R2 in this opamp circuit for several different values of R2:
For each value of R2, what is it that establishes the amount of current through it? Do you see any practical value for a circuit such as this?
This circuit acts like a current mirror, except much more precise.
Follow-up question: what factor(s) limit the greatest resistance value of R2 that the operational amplifier may sustain 3 milliamps of current through?
Besides reviewing the purpose of a current mirror circuit, this question draws students’ attention to the current-regulating capabilities of an operational amplifier by having them analyze it as though it were simply a non-inverting voltage amplifier circuit.
Explain how the operational amplifier maintains a constant current through the load:
Write an equation solving for the regulated load current, given any relevant variables shown in the schematic diagram (R1, VZ, Vsupply, AV(OL), etc.).
Follow-up question: is the transistor sourcing current to the load, or sinking current from it?
Challenge question #1: modify the given equation to more precisely predict load current, taking the β of the transistor into account.
Challenge question #2: modify the location of the load in this circuit so that the given equation does precisely predict load current, rather than closely approximate load current.
This is a good example of how operational amplifiers may greatly improve the functions of discrete-component circuits. In this case, the opamp performs the function of a current mirror circuit, and does so with greater precision and reliability than a simple current mirror ever could.
It should be noted that the equation provided in the answer does not directly predict the current through the load, rather it predicts current through resistor R2. This is equal to load current only if the transistor’s base current is zero, which of course it cannot be. The real equation for predicting load current will be a bit more complex than what is given in the answer, and I leave it for your students to derive.
Write an equation solving for the regulated load current, given any relevant variables shown in the schematic diagram (R1, VZ, Vsupply, AV(OL), etc.). Also, describe what would have to be changed in this circuit in order to set the regulated current at a different value.
At first glance, the feedback appears to be wrong in this current-regulating circuit. Note how the feedback signal goes to the operational amplifier’s non-inverting ( ) input, rather than the inverting input as one would normally expect for negative feedback:
Explain how this op-amp really does provide negative feedback, which of course is necessary for stable current regulation, as positive feedback would be completely unstable.
If current increases, the feedback voltage (as measured with reference to ground) will decrease, driving the op-amp’s output in the negative direction. This tends to turn the transistor off, properly correcting for the excessive current condition.
The purpose of this question is to get students to realize negative feedback does not necessarily have to go into the inverting input. What makes the feedback “negative” is its self-correcting nature: the op-amp output drives in the direction opposite a perturbation in the measured signal in order to achieve stability at a control point.
Predict how the operation of this current regulator circuit will be affected as a result of the following faults. Consider each fault independently (i.e. one at a time, no multiple faults):
For each of these conditions, explain why the resulting effects will occur.
Follow-up question: which of the two opamp power terminals (Vsupply or Ground) carries more current during normal operation, and why?
The purpose of this question is to approach the domain of circuit troubleshooting from a perspective of knowing what the fault is, rather than only knowing what the symptoms are. Although this is not necessarily a realistic perspective, it helps students build the foundational knowledge necessary to diagnose a faulted circuit from empirical data. Questions such as this should be followed (eventually) by other questions asking students to identify likely faults based on measurements.
The simplest electronic device capable of converting a current signal into a voltage signal is a resistor:
Precision resistors typically work very well for this purpose, especially when the amount of voltage dropped across it is of little consequence. This is why shunt resistors are frequently used in power circuitry to measure current, a low-resistance “shunt” resistance element dropping voltage in precise proportion to the current going through it.
However, if we cannot afford to drop any voltage across a resistance in the circuit, this technique of current-to-voltage conversion will not be very practical. Consider the following scientific apparatus, used to measure the photoelectric effect (electrons emitted from a solid surface due to light striking it):
The current output by such a phototube is very small, and the voltage output by it is smaller yet. If we are to measure current through this device, we will have to find some way other than a shunt resistor to do it.
Enter the operational amplifier, to the rescue! Explain how the following opamp circuit is able to convert the phototube’s weak current signal into a strong voltage signal, without imposing any significant resistance into the phototube circuit:
The design of this circuit is complicated by the existence of bias currents at the opamp inputs. You may find it helpful to analyze a simplified version of the same circuit. Please bear in mind that this simplified circuit would only work if the opamp had absolutely no input bias currents at all:
Note to your students that this is one of those applications where even “tiny” input bias currents can affect the results. In this particular case, the phototube outputs miniscule current at best, and so we must compensate for the existence of opamp bias currents.
Shown here is a simple circuit for constructing an extremely high input impedance voltmeter on a wireless breadboard, using one half of a TL082 dual op-amp:
Draw a schematic diagram of this circuit, a calculate the resistor value necessary to give the meter a voltage measurement range of 0 to 5 volts.
R = 5 kΩ
Follow-up question: determine the approximate input impedance of this voltmeter, and also the maximum voltage it is able to measure with any size resistor in the circuit.
This is a very practical circuit for your students to build, and they may find it outperforms their own (purchased) voltmeters in the parameter of input impedance! Be sure to ask them where they found the information on input impedance for the TL082 op-amp, and how they were able to determine the maximum input voltage for a circuit like this.
by Dale Wilson
