Discrete Semiconductor Devices and Circuits
Class B BJT Amplifiers
12 questions By Tony R. Kuphaldt
Page 1 of 4 0 of 12 answers revealed (0%)
  • Question 1 of 12
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction, choosing resistor values high enough to make damage to any active components unlikely.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all voltage and current values.
    6. Carefully measure all voltages and currents, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    When students are first learning about semiconductor devices, and are most likely to damage them by making improper connections in their circuits, I recommend they experiment with large, high-wattage components (1N4001 rectifying diodes, TO-220 or TO-3 case power transistors, etc.), and using dry-cell battery power sources rather than a benchtop power supply. This decreases the likelihood of component damage.
    As usual, avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading” (on the high end) and to avoid transistor burnout (on the low end). I recommend resistors between 1 kΩ and 100 kΩ.
    Reveal answer
  • Question 2 of 12
    The circuit shown here is a standard push-pull amplifier, comprised of a complementary pair of bipolar junction transistors:
    Trace current in this circuit during periods of time when the instantaneous voltage of the signal source (Vin) is positive, and for those periods when it is negative. Determine at which times each of the transistors is “on” (conducting current).
    Reveal answer
  • Question 3 of 12
    Class B amplifiers are greatly preferred over Class A designs for high-power applications such as audio power amplifiers. Explain why this is.
    Reveal answer
Worksheets
AAC Worksheets
