DC Electric Circuits
Current Divider Circuits
10 questions By Tony R. Kuphaldt
Page 1 of 4 0 of 10 answers revealed (0%)
  • Question 1 of 10
    Don’t just sit there! Build something!!
    1. Carefully measure and record all component values prior to circuit construction.
    2. Draw the schematic diagram for the circuit to be analyzed.
    3. Carefully build this circuit on a breadboard or other convenient medium.
    4. Check the accuracy of the circuit’s construction, following each wire to each connection point, and verifying these elements one-by-one on the diagram.
    5. Mathematically analyze the circuit, solving for all values of voltage, current, etc.
    6. Carefully measure those quantities, to verify the accuracy of your analysis.
    7. If there are any substantial errors (greater than a few percent), carefully check your circuit’s construction against the diagram, then carefully re-calculate the values and re-measure.
    Avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistors between 1 kΩ and 100 kΩ, unless, of course, the purpose of the circuit is to illustrate the effects of meter loading!
    Reveal answer
  • Question 2 of 10
    We know that the voltage in a parallel circuit may be calculated with this formula:
    E = Itotal Rtotal
    We also know that the current through any single resistor in a parallel circuit may be calculated with this formula:
    IR = E
    R
    Combine these two formulae into one, in such a way that the E variable is eliminated, leaving only IR expressed in terms of Itotal, Rtotal, and R.
    Reveal answer
  • Question 3 of 10
    What will happen to the current through R1 and R2 if resistor R3 fails open?
    Reveal answer
Related Tools:
