Discrete Semiconductor Devices and Circuits
Design Project: AC-DC Power Supply
5 questions By Tony R. Kuphaldt
Question 1 of 5
Safety is very important when designing and/or building a device powered by potentially lethal electrical sources such as residential AC line power. Explain how you can prove that the metal case of your power supply is indeed “grounded” for safety, such that an internal fault from one of the “hot” conductors to the metal case will result in a short-circuit that will trip the power receptacle’s fuse or breaker rather than shock the individual touching the case?
Hint: a visual inspection is not good enough, and we don’t want to actually create a ground fault situation to test the grounding.
Reveal answerMeasure resistance from the ground prong on the power plug to the metal case. The resistance should be no more than a few tenths of an ohm. A resistance measurement of 0.5 ohm or more indicates a poor connection.
Notes:As a general policy, I inspect each and every one of my students’ power supplies before energizing for the first time. This does not mean, though, that I am the one making the meter measurements! Each student must prove to me that their grounding is adequate by making the meter measurement under my direct supervision. This way, they learn how to do it themselves while safety is still personally ensured by me.
I also have the students tug on the wire connections while making this test, to ensure that it is not a random low-resistance measurement we are seeing with the ohmmeter. Loose wire connections are best tested by resistance measurements under mechanical stress, not by visual inspection alone.
Question 2 of 5
When connecting components together to build your power supply, it is important that you use the proper type(s) of wire. Identify what characteristics are required for the wires you use in this project, for each of the following parameters:
- Wire gauge:
- Insulation type:
- Stranding (solid or stranded):
Reveal answer- Wire gauge: sufficient for the maximum current expected
- Insulation type: sufficient for the maximum voltage expected
- Stranding (solid or stranded): stranded preferred
For the first two parameters, identify the values of expected current and voltage to be encountered in your power supply circuit, for both the AC and the DC sections.
Why do you suppose stranded wire might be preferred for a project such as this? I’ll give you a hint: it is not for any electrical property of the wire as much as it is for mechanical considerations.
Notes:Ampacity figures may not be readily available for wires of the gauge most electronics students are accustomed to dealing with. However, ampacity for small-gauge wire may be roughly calculated by plotting data points of published wire ampacities for wire of several larger gauges, and then extrapolating downward on the gauge scale. If nothing else, this would be a great example to students of how to use simple statistical techniques (regression, curve fitting, plotting) to make practical estimations.
Question 3 of 5
How do we tell which winding of the step-down power transformer is the primary, and which is the secondary, without actually powering it up with AC line power? This is often an issue when students purchase cheap transformers that are unmarked and undocumented.
Reveal answerUse an ohmmeter to measure the resistance of each winding. The primary winding of a step-down transformer will contain a longer length of wire, of smaller cross-sectional area, than the secondary winding. With these two factors, the resistance difference between windings should be obvious.
Notes:Care should be taken if the transformer in question is a complete unknown. It may be impossible to tell what the respective voltage ratings of the windings are if one does not even know whether the transformer was designed for line power (120 volts, 60 Hz AC in the United States) or not. Small power transformers are easy enough to obtain from electronics parts suppliers and from scrap consumer electronic devices (stereos, computer accessories, etc.) that no one should have to take chances with a completely unknown transformer.
