Martin Stumpf
Martin Stumpf Marget Segment Manager, High-Speed Digital Design Test, Rohde & Schwarz
ABOUT
Martin Stumpf is a Segment Manager for High-Speed Digital Test at Rohde & Schwarz. He joined Rohde & Schwarz in 1990 as a R&D Engineer and has worked in research & development, project management, product management, regional support and business development. Martin holds an EE degree from Technical University of Munich.
Benjamin Dannan
Benjamin Dannan Founder & Chief Technologist, Signal Edge Solutions, Rohde & Schwarz
ABOUT
Benjamin Dannan is the Founder and Chief Technologist at Signal Edge Solutions, specializing in signal and power integrity (SI/PI) design, high-speed circuits, and multi-layered PCB design. With extensive experience as a consultant, he focuses on developing advanced packaging solutions for high-performance ASICs, chiplets, and complex FPGA designs.
Elevate Your Power Integrity Measurements: Analyzing Large Signal Phenomena and Crosstalk in Time & Frequency Domain and Avoiding Ground Loop Effects
Ensure precise power integrity measurements in your PCB designs. Watch this webinar to gain expert insights and advanced techniques for accurate analysis.
In partnership with Rohde & Schwarz
Webinar Overview
As electronic designs evolve, managing power fluctuations becomes increasingly challenging due to lower voltage levels and tighter component tolerances. With rising data rates, shrinking supply voltages, and higher integration densities, issues such as jitter, noise, frequency-dependent loss, reflections, and crosstalk are more common than ever. These factors can significantly affect power rails, resulting in voltage sag and ground bounce. Power rail disturbances in return have an increasing effect on signal integrity, particularly through power supply induced jitter and amplitude noise.
Thus, analyzing power integrity and the performance of the power delivery network (PDN) on a printed circuit board (PCB) is now an essential part of the digital design process.
But how to measure as accurate as possible to ensuring power integrity? Join our upcoming webinar to gain expert insights and learn advanced techniques that will help you elevate your power integrity measurements.
You will learn:
  • Analyzing large and small signal phenomena and the corresponding way of testing them
  • Measuring PDN Crosstalk in the time and frequency domain
  • Ground loop effects and how to avoid them
Free Webinar Registration
