How to Defeat Heat with Peltier Devices
In this webinar, CUI Devices (now Same Sky) provides a technology overview, application examples, resources, and more to help you defeat heat in your next project.
Peltier modules, also known as thermoelectric coolers (TEC) or thermoelectric modules (TEM), are solid state devices which transfer heat from one side to the other when electrical power is applied. Although they may look nondescript to the untrained eye, don't let their white square form factor fool you. These reliable, solid-state components pack a punch when it comes to applications that require precise temperature control, cooling to below ambient temperatures, and fast temperature response and immediate cooling.
