Humanoid Robotics: Deterministic Motion Control & Edge AI Systems
Discover the system architectures enabling stable, responsive humanoid robots in real-world environments.
Webinar Overview
Humanoid robots operating in real-world environments must coordinate perception, decision-making, and motion with extremely low latency and deterministic control. Achieving that performance requires more than powerful central compute—it depends on how intelligence, connectivity, sensing, and control are architected across the entire robot.
In this technical webinar, explore the system architectures that enable responsive, stable humanoid motion. We’ll examine how distributed intelligence balances central processing with edge and embedded control, enabling real-time execution across high-degree-of-freedom systems.
You’ll also see how time-synchronized, deterministic connectivity and high-bandwidth sensor links help keep perception, decision, and actuation tightly coordinated—and how multiturn position sensing enables precise motion from startup without the need for re-homing.
From perception and compute to sensing, motion, and control, this session provides a systems-level view of the technologies required to build humanoid robots that perform reliably in dynamic, real-world environments.
Attendees will:
- Understand how to partition intelligence across central, edge, and embedded processing for responsive, deterministic humanoid control
- Explore how time-synchronized connectivity coordinates perception, decision-making, and actuation across the robot
- See how multiturn position sensing enables precise startup position, repeatable motion, and operation without re-homing
