Industry White Paper
Autoranging DC Power Supplies
Programmable DC power sources are an essential tool in product development and production testing of a wide range of electronic devices and systems. In many instances, functional test requires submitting the device-under-test (DUT) to a wide range of operating conditions. In some cases, the DUT draws constant power under variable input conditions.
Topics Covered
Principle of Autoranging
Advantages of Autoranging
High Power Solutions
Digital Remote Interfaces
Application Note Overview
“Autoranging” is a term used when a programmable DC source automatically offers a wide output range of both voltage and current to maintain full power output across a wide operation range. Programmable DC power sources are an essential tool in product development and production testing of a wide range of electronic devices and systems. In many instances, functional test requires submitting the device-under-test (DUT) to a wide range of operating conditions.
With the rising penetration of energy-consuming native direct current (DC) loads in commercial and residential applications, and the increasing focus on the adoption of energy-efficient systems to fulfill ambitious national goals, the debate over the relative merits of AC- versus DC-based systems has intensified.
The components include converters (central rectifiers and DC-DC converters), DC circuit breakers, DC power distribution units (PDUs) and DC power management systems (monitoring and control) installed for building-level, floor/room-level, and device-level conversion.
In this application note, you'll learn:
  • The principle of autoranging
  • Autoranging applications and examples
  • The advantages of autoranging
Read Application Note:
