Industry White Paper
Autoranging: Theory of Operation
Programmable DC power sources are an essential tool in product development and production testing of a wide range of electronic devices and systems. In many instances, functional test requires submitting the device-under-test (DUT) to a wide range of operating conditions. In some cases, the DUT draws constant power under variable input conditions.
Application Note Overview
Common examples are DC motor drives and regulated DC/DC supplies. In such circumstances, the ability of the programmable DC source to provide increased current at reduced output voltage is valuable. This ability is known as “Autoranging." DC supplies without Autoranging often require users to oversize or use multiple supplies to test the DUT under varying input voltage conditions.
In this application note you'll learn:
The principle of autoranging
Autoranging applications and examples
The advantages of autoranging
