Industry White Paper
Battery Simulation with DC Power Supply R&S®NGM200
This application note is about creating your own battery model for the R&S®NGM200, beyond the standard models provided within the battery simulation option NGM-K106.
Application Note Overview
This application note is about creating your own battery model for the R&S®NGM200, beyond the standard models provided within the battery simulation option NGM-K106. The main purpose is to gradually discharge a battery or a rechargeable battery using the internal QuickArb function which can then be recorded using the fast data logging functionality FastLog and stored in a .CSV file. This file can then be adapted to be used as a battery model in the battery simulation mode of the R&S®NGM200.
For this purpose, Rohde & Schwarz provides a tool for developers to make their work easier. This tool calculates all the data required for a battery model. The following chapters describe the procedure from building an arb file up to working with the tool.
