Industry White Paper
Common Mistakes in Power-Supply Layouts and How to Avoid Them
Power Supply Design: The physical layout is just as critical to the performance of your power-supply design as the selection of the semiconductor devices or surrounding passive components.
Seminar White Paper Overview
Every power supply layout is different, but what remains consistent is that in order to produce a good layout, you must understand the circuit fully and the environment or application that the board will be a part of. Carefully consider each block of components on the schematic, whether they are there for safety, EMI, feedback, thermal relief, and so on.
In this white paper by Texas Instruments, learn about the common mistakes in power-supply layouts and ways to avoid them. Explore topics such as the importance of the placement of:
- Input capacitor
- Filter component
- Gate driver
- Magnetic component
