Industry White Paper
Compact 1.27mm Pitch Connectivity from Board-to-Board to Cable Assemblies
Running out of board space? Adam Tech’s ESMC Signal Series delivers high-density connectivity in a compact 1.27mm pitch, with 2 to 80 positions, flexible board-to-board configurations and matching cable assemblies. Download the application note from Adam Tech to find the right fit for your design.
November 06, 2026 by Sourceability
Product Overview
As industrial controls, telecoms equipment, automotive electronics and embedded systems keep shrinking, designers must fit more signal connections into less board space without giving up reliability or layout freedom. Picking a connector family that can handle different board arrangements, stacking heights and cable runs can make a big difference to how easily a design comes together.
This product briefing introduces Adam Tech’s ESMC Signal Connectors and Cable Assemblies, a 1.27mm pitch family in 2 to 80 positions. It covers the board-to-board configurations, mounting and retention options, and matching cable assemblies, which together give engineers a consistent way to connect boards and modules in compact, modular systems across a wide range of applications.
Read White Paper:
